Re: A15 Front Main Seal
From Christchurch NZ
I'd wager it'd be a piece of piss.
Posted on: 2012/7/12 9:00
Forced Induction!
You probably could. Screw a large sheet-metal screw in the old seal and pull it out.
(after removing the pulley and the key)
Then grease up the inside of the new seal and carefully drive it on.
Never done it that way...
Posted on: 2012/7/12 5:38
From Melbourne, Australia
Do you have to take the timing cover off?
Correct me if I'm wrong but can't you just take the balancer off and removed the seal???
I've never done one on a Datto but presume it would be the same unless they're totally different design?
It would be easier to replace the seal with the timing cover off but a lot more work involved to get it off in the first place.
Posted on: 2012/7/12 5:32
Current Fleet-
1996 R33 GT-R Skyline
1996 Falcon XH XR6 Ute
1977 Datsun 1200 Ute A14 (Fergus)
2012 VW Passat TDI Wagon
Don't forget the drain the radiator...
Posted on: 2012/7/12 5:27
There are many problem that can occur. But it is fairly easy.
Lower the pan, remove the timing cover. Drive the new seal in.
Posted on: 2012/7/12 5:25
A15 Front Main Seal
From Sunny Coast Qld
Hi guys,
How hard is it to change the front main seal on an A15, I have a minor leak? Are there any problems I might encounter?
Greg
Posted on: 2012/7/12 4:44
Greg
