Browsing this Thread:
1 Anonymous Users
Re: silvia brakes on 120y strut |
hey mate have u got any of these adapter plates for the b110 struts for s13 calipers cheers kyle 0401585747
Posted on: 2013/8/31 2:58
From Trinidad and tobago
what calipers from nissan could fit on b310 stock disc setup?
Posted on: 2013/6/1 3:30
'71 Four Door Sedan. A15 Engine + Lighten Flywheel. E15 Electronic Ignition 32/36 Weber EI Coil 4 into 2 into 1 Extractors 1 3/4 Exhaust Pipe Semi Flow Hotdog 60 series Gearbox H150 Diff.
Street Sleeper!
STILL LIVIN' THE 70'S LIFE !!
Registered Users Contentmaster Usermaster
Datsun 1200 & 120Y use heavy-duty bearings to start with -- same ones are used by 520/620 pickups! Back the bearings and adjust them correctly and they will last forever.
And S13 brakes only change the offset 7mm, so not a lot.
Posted on: 2013/5/9 2:15
From Kyoto Japan
These brackets are nice but no one seems to take into account the wheel bearing loading. I would only using them on the 120Y/pbr struts with the bigger bearings. The extra breaking forces combined with wider wheels and different offsets can quickly eat bearings. I like Datsuns on the road not on the side of the road with 3 wheels.
Posted on: 2013/5/8 14:17
guard mirrors, whitewalls.....life's almost complete.
Club Sunny Truck - REPRESENT! Hayashi Racing Secret Factory Japan
From Springwood NSW, Formerly Tas.
I reckon I'll just use the 120y M/C and booster.
Posted on: 2013/5/8 13:13
1978 120y Coupe.
Not too shy to talk
How do you guys rate the 250mm discs for track work? I want to stick with 13's for my sunny excellent replica but from what I can find they ran Girling 4 spot calipers which I am guessing will be pretty much unobtainable.
Posted on: 2013/5/8 10:17
From A-TOWN
im using a brand new 120Y master, no booster. Boosters are gay.
Posted on: 2013/5/8 8:44
Not too shy to talk
What brake booster/master cylinder are you going to use with the s13 brakes...
Posted on: 2013/5/8 8:36
yeah cool, the same brand also makes longer standard ones so i might just buy one of each and see what they look like.
i'll post pics when i've finished the conversion.
Thanks
Posted on: 2013/5/8 6:40
1978 120y Coupe.
120Y studs have 13.0 mm knurl with 10mm shoulder S13 studs have 12.83 mm knurl with 14mm shoulder
S13 studs will fit the 120Y hub, go in and center properly. They are approximately 13mm longer, which is needed because the rotor face goes over the hub.
Posted on: 2013/5/8 6:09
