(1) 2 3 4 ... 6 »
Re: Time to clear the air!
thanks to Benny for finding it on yahoo auctions about 1700 inc headers.
jpg  mini manifolds.jpg (40.99 KB)
737_50a484d528fb3.jpg 600X450 px
Posted on: 2012/11/15 5:59
maybe wall thickness can be increase also and height reduced a tad more if you like the equal flow will still be there regardless of a 1cm or 2cm less which will be easier to cnc if needed for a casting or just billet runs for those interested.
Posted on: 2012/10/24 1:16
From Adelaide
hey d i'm hoping to make those changes in next few days. will let you know when done.
Posted on: 2012/10/23 22:39
HY_FLO MOTORSPORT - designing a new wave in motorsport
hy.flo912@gmail.com
0411 725 347
www.facebook.com/HyFloMotorsport
FOLLOW ME
efi nipples on the outside (sorry for quality but idea is hopefully there?)
jpg  modded mini man efi option.JPG (19.02 KB)
737_5080ada516b8d.jpg 357X386 px
Posted on: 2012/10/19 2:32
I hear you Dave :)
the longer pipe can be tigged on according to preferred owner setup.
Here is another take (a bad one should be tapered curved but couldnt do it) of using reinforcing bridges and later maybe add some midway injector nozzle embossed nipples to face the inlet ports straight on from midway on the outside in case someone wants injection they the material is there to just drill and tap. If not can easily be machined off the side.
jpg  modded mini man.jpg (17.39 KB)
737_5080abde0c838.jpg 357X386 px
Posted on: 2012/10/19 2:23
From Adelaide
yer my reason for it being that tall was the flow would be straighter thus being more effective i will do an other one over weekend make it a tad shorter and a wider mouth but we def on a winners here dave
Posted on: 2012/10/19 1:30
hy.flo912@gmail.com
0411 725 347
FOLLOW ME
comparison doesnt need 2 into 1 section touched just top section with bigger inlet and tapered a little more straight.
40mm should do as it will suit easy to source weber trumpets or velocity stacks and make it easier to make a plenum then. You could also supply the plenum laser cut to suit.
jpg  mini mani comparison.jpg (30.41 KB)
737_507fe365ad6db.jpg 713X386 px
Posted on: 2012/10/18 12:12
From Adelaide
i will mess with it later i gotta put a a cupboard together for my son :D
Posted on: 2012/10/18 10:00
hy.flo912@gmail.com
0411 725 347
FOLLOW ME
Be better with trumpets too D
Here is the modified one I did on photoshop just need to be a tad shorter so 2 into 1 blend happen a little earlier of smother closer to the top. Also top should be tapered closer to the pipe to weld on so there are no discrepancies with flow and made a tad wider on the main inlet. So just a few mods.
jpg  mini mani.jpg (16.14 KB)
737_507fc498f35b9.jpg 365X405 px
Posted on: 2012/10/18 9:58
(1) 2 3 4 ... 6 »
