Re: Motorsport Auto, Zcar National event!
Quite a regular
From San Diego, CA
Daniel,
hope this works...(image)
Posted on: 2002/5/7 19:14
Quite a regular
From San Diego, CA
I'm sure it will, I'll double check my spare intake and carbs...
Cel
Posted on: 2002/5/7 18:47
Webmaster
From Lisbon - Portugal
Webmaster
Cannon? Can you post an image? Will a 40 DCOE Weber fit?
Thanks for the info.
daniel
Posted on: 2002/5/7 18:17
Keep them alive and sideways!
Quite a regular
From San Diego, CA
Daniel,
Actually, they are 44 mikuni
Posted on: 2002/5/7 17:49
Webmaster
Webmaster
Thanks! Great paint job!
Is that a weber setup?
If it is, what kind of intake manifold did you used?
daniel
Posted on: 2002/5/7 16:03
Quite a regular
From San Diego, CA
Posted on: 2002/5/7 14:41
From Fort Worth, Texas, USA
That, my friends, is a Predator variable venturi carburetor on a Z-car. It is similar in function to the SU but in a downdraft. It uses two "air doors" above the throttle plates that open up with the airflow and regulate the amount of fuel the engine sees. There is a wing shaped fuel bar in the "shadow" of these doors that forms the venturi and draws the fuel from the bowl. I wanted to try one on one of my cars but since they were designed for big honkin' V8s, I figured it would be too much carb. Besides, I think they are a bit pricey too.
Posted on: 2002/5/7 13:05
Webmaster
Webmaster
Hi,
Great pics! and great Z's...
But I have two questions, where is the 1200? and what the hell is this!?
daniel
<small>[ Edited by danielblues on 2002/5/7 8:08:47 ]</small>
Posted on: 2002/5/7 8:01
Quite a regular
From San Diego, CA
Guys,
The show was great! I was the only 1200 out there...(I think) lots of great Z's and lots of questions regarding the 1200. Made new friends all across USA. Lot's of guys still can't believe that 1200 are still around...YEAH! makes me proud that I have two
Posted on: 2002/5/7 3:18
