Re: Check Leaking Valve Seat ?
Yes, both must be perfect.
Posted on: 2013/1/19 6:04
From Malaysia
you need perfect seat for both in and ex. lap your valves.
Posted on: 2013/1/19 5:48
From Sri Lanka
Hi Guys
Do i need to check perfect seat on both valve intake and exhaust ? which is critical intake or exhaust ?
thanks
regards
sumith
Posted on: 2013/1/19 4:43
If the head is assemled (valve springs installed), it should not leak through even if you leave it overnight.
If it leaks into the ports, hand-lap the valves.
1. Check surface flatness yourself. Most A12 do not need head skimming (head milling). Use a straightedge and a .004 inch feeler gauge. It is allowed to be up to .004 from flat but I've never even seen that much even after overheating and blown gaskets. Normal is .002 per the Datsun factory service manual.
2. carry a water bottle. Place the head upside down and fill the combustion chamber with water. If it holds for 5 minutes, the valves are sealing good.
3. check for play on a valve stem. Use a small compressor (I paid $10 for one at a flea market) and see if the valve is tight side-to-side. If it's not, go on to the next head. If it is tight, check a few more (or all of them). Visually inspect for gauges in the head face and manifold faces. Clean-looking heads are best. Pass on slightly rusty heads. Wiggle the valves to see if the guides are OK (this is the part most often wearing out on A12). There should be almost no discernable wiggle with the valve slightly off the seat. If there is, it requires new guides ($$$).
Posted on: 2013/1/7 4:37
From Sri Lanka
Hi Guys
How to you Bench Test you Valve seat whether they are leaking or not before fit it to the engine Block ?
Yesterday i fixed My b210 engine including new set of rings and bearing etc .and fixed the valve to the head and Put a little fuel into the manifold chamber all the valve became wet within 5 minutes, will that be a proper test or can be managed ,fuel is poring out but slowly valve become wet,
Do i need to machine valve seat again , is it essential to do valve guide also with that ?
Help me guys
thanks
regards
sumith
Posted on: 2013/1/7 4:07
