Re: a12 reliable power options
17 second 1/4 mile
Posted on: 2013/2/3 18:44
From sydney.nsw
that's a big call for anyone to make. to many other things that can affect the times.
Posted on: 2013/2/3 8:38
A.T.E RACE ENGINES: ( " AUST 1 " 2010 ) A15 GO THE DATTOS... 0412 864 741
Bige.
What sort of 1/4 times could you expect with that setup in a 1200ute?
Posted on: 2013/2/3 8:30
From sydney.nsw
all the above, but with a a14 crank & 76mm bore.all in a A12 block NO ENGINEERING, "GOTA LOVE THAT"
Posted on: 2013/2/3 6:35
From Central Vic
Valve springs oval port head oval port head/manifolds and ute diff 4.1:1 ratio and you would have a nice little toy that would rev when you wanted it but still return good economy if you stick with the stock cam
if you want a bit more fit the falcon Weber but make sure you spend the time to jet it up right or it will be hard to drive
you should be able to get the head and manifolds for a couple of hundred and the valve springs for hundred more diff probably couple hundred
pretty cheap fun good luck
Posted on: 2013/2/3 6:27
to buy or not to buy???? OK
This is the reason I have five coupes
Spacers are indicated if you are revving over 7,000 RPM.
Go with a mild cam for low RPM usage.
If you want a power increase over the stock cam, which means revving the engine higher, use a GX cam or equivalent (6500 RPM usage).
I recommend the stock cam. It is perfect for reliable power in the 3000-6000 RPM range.
> what's a reasonable over bore size thatd still give me some room in the future
Well since you can go 76 mm in the future, any regular overbore size is fine: 73.5 or 74.0 or 74.5. If the bore are still good, skip overbore and just hone it and new rings. (a +1 mm overbored is good for approximatly 9-tenths horespower (.9) increase).
Posted on: 2013/2/3 2:45
From Sydney, NSW
now that sounds like the best idea! bit of decomrpession and away you go!
Posted on: 2013/2/2 6:36
Snapped crank and still smiling, How do I do it? LOL
From mandurah
or save a heap of cash and make more power and still be 100% drivable and do an a12 turbo
easy and cheap! ,just did a turbo setup on a toyota 4k and it was well worth the 200 dollars spend doing it
just buy a stromberg cd175 carby or a 1'3/4 su carby and then make a j pipe off the stock manifold ,then use a carbon seal equipt turbo or even one without a carbon seal ,then theres oil line and stuff
super easy to to and goes like a shower of #OOPS# ,plus its not hard to srive like a cammed na motor can be and is still reliable is its tuned ok
we found if you use a stromberg off a volvo the jetting is realy close for the 4k and should be just the saem for an a12
cheers
Posted on: 2013/2/2 5:28
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
From Sydney, NSW
well i was told that if your getting up high rpm it keeps the rockers from shifting side to side. because it replaces the spring between each rocker
Posted on: 2013/2/2 2:23
From Sydney, NSW
hey Dion 120y sorry Im not familiar with the concept of rocker spacers what do they do to help performance?
Posted on: 2013/2/1 21:15
