Re: Datsun 1200 12a conversion
Nsw
Posted on: 2013/2/12 5:21
From A-TOWN
where are you located?
Posted on: 2013/2/11 10:32
Thanks everyone for the replys and datsunbloke some of them parts would be very useful
Posted on: 2013/2/11 5:04
From A-TOWN
Best to jump on ausrotary.com, do a bit of a search if you can, its be done many times before and the cunts there should be able to help you out.
What city do you live in?
I can point you in the right direction if your in Adelaide, Vic or QLD.
If your in SA ive got an allot radiator, fuel system, oil cooler, IDA EFI and a few other rotary parts that could come in handy if your chasing anything.
Posted on: 2013/2/9 20:50
Everybody welds it in slightly different places. As far back is possible is better for peformance, but farther forward makes it easier to fit in. Put the powertrain in place, mark where the mounts line up, the weld it there.
Posted on: 2013/2/9 20:22
okay no worries does anyone no the dimensions of like how far from the radiator support to weld the mounts
Thanks
Posted on: 2013/2/9 8:59
There is no kit. But it's much like any other engine swap. See photos and overview at Mazda rotary engine swap
Posted on: 2013/2/5 19:51
From A-TOWN
Posted on: 2013/2/5 10:23
From A-TOWN
you can do it pretty easily, make up a plate to go over the front cover, will have 4 bolts in it, then some square tubing to the rails with some angle iron welded on the end and bolted to the datsun rails if you wanna solid mount it, otherwise ive seen it done but putting bushes on the end similar to swing arms so you have a bit of movement there. You could probably modify a RX3 x member and mount to fit, pretty sure some dude makes repo ones for a decent price.
Posted on: 2013/2/5 10:19
Hi everyone I recently bought a datsun 1200 ute project came with a 12a rotary which I am wanting to put in it already has the bigger tunnel in it just needs the mount and was wondering if anyone has a kit or something to get the motor put in
Thanks Sean
Posted on: 2013/2/5 9:29
