Re: Tyre Touching Front Shocks While Turning ?
True that.
From the photo it can be seen it is not a camber problem. It is the wrong wheel fitted (too much positive offset).
Posted on: 2013/5/20 6:46
From Sydney
Looking at the tyre wear, Excessive negative camber will also bring the tyre closer to the strut body, provided the negative was dialed into the strut by bending the the strut body at the base adjacent to the axle spindle.
Posted on: 2013/5/20 6:01
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
That is the wrong wheel for a Datsun. It is most likely from a FWD car.
Get a Datsun or Toyota rear-wheel-drive wheel.
Posted on: 2013/5/20 5:55
From Bendigo, Victoria
Is it a front wheel drive rim??
Posted on: 2013/5/20 5:46
From Sri Lanka
Hi Guys
Look at this and what should be done to avoid this am i using different Shcoks or what is wrong here ? i think i would not be able to use higher rim size like 14, yet it will touch the shocks
thanks
regards
sumith
jpg  1.jpg (69.17 KB)
10994_5199a51ef0508.jpg 480X640 px
jpg  2.jpg (78.38 KB)
10994_5199a52821f46.jpg 480X640 px
Posted on: 2013/5/20 5:23
Yes, something is WRONG.
In a stock B210, there is no possible way this can occur. The stock 4x12" wheel positions the tire far, far away from the strut tube.
* Wheel: 4x12" +30
* Tire 155SR12
Posted on: 2013/2/9 20:28
Maybe wheel off set is the problem
Posted on: 2013/2/9 6:19
Car free
From Sri Lanka
Hi Guys
This is my 120Y , when i look down the wheel from inside it sees the tyre is almost very closer to the shock absorber body.i will upload a snap probably on monday, how it looks
thanks
regards
sumith
Posted on: 2013/2/9 5:45
Sounds like wheel bearing to me as well
Posted on: 2013/2/9 0:05
Car free
Sounds like something not right there. Is this on 120y or the b310?
Posted on: 2013/2/8 12:55
