Re: DHLA 40's
From Sydney, NSW
ok cool, that's not a bad idea, havn't heard that one before lol
cheers for the feedback guys
Posted on: 2013/4/1 5:58
Daily: 2000 Holden VX Calais 5.7L GenIII
Datto: 1972 Datsun 1600 L20B twin 40 DCOE Webers
Re: DHLA 40's
2 turns out is the rebuild setting. Not an adjustment per se.
Yes, it is "best lean idle", just as you say:
adjusted back in to lean it out, until you can hear a change then bring it back out til it runs better
You can use a special synchronizer hardware or manometer -- or just a piece of hose to your ear. When both have the same tone, they are in sync.
Posted on: 2013/4/1 5:55
Re: DHLA 40's
From Sydney, NSW
and use a manometer to adjust air bypass valve, im aware of ALL of that :) but with all carbs ive always started with the mixture screw about 2 turns out and adjusted back in to lean it out, until you can hear a change then bring it back out til it runs better, that was the position I was wondering about, where people 'start' from hahaha all good.
Posted on: 2013/4/1 5:47
Re: DHLA 40's
Synchronize your carburetors. I don't use a "starting setting" -- just adjust them for best lean idle. But just as importantly, synchronize them (adjust the linkages dynamically).
Posted on: 2013/3/31 17:53
Re: DHLA 40's
I would like to hear some options on this also?!
I have a single side draft 45dcoe on my mild a12 and that tends to give off a little bang when I blip the throttle to downshift, gives me a bit of a fright sometimes. Though bit may have been too much fuel, ie. running just a little to rich... But not sure, haven't had the chance to have it dynoed yet so could be anything...
Posted on: 2013/3/31 10:55
1200 Ute - Mild A12
1200 Ute - Donor Shell Sold
1200 Coupe - A14 EFI SC
Re: DHLA 40's
I had a similar problem with my 240z (triple 45 dcoe webers) it would cough and spit at light throttle openings.
I stripped and cleaned them out and also replaced the soft mount gaskets.
It still coughed and spitted.
In the end I re-set the linkages and it was all good.
Maybe this could be your problem, check them first before spending your hard earned.
Cheers,
G
Posted on: 2013/3/31 8:02
Jesus drove a datsun
`67 B10 Turbo white
`69 VB10 red
`71 S30 (240z) orange 432R style
`78 P330 (280c) president matte black
`76 p330 (260c) wagon silver
`96 Toyota Hiace 2.8 diesel LWB
Re: DHLA 40's
From Sydney, NSW
hahaha sorry dd, think i didnt explain properly, what is the STARTING position for the mixture? for example 2 1/2 turns out then tune?
Posted on: 2013/3/31 7:53
Re: DHLA 40's
The normal position is tune-by-ear. In other words, do not set it "to a certain position" and leave it there. Tune it to best lean idle (as with any carburetor), and synchronize the two carburetors (as with any twin carbies).
Turning the idle mixture screw to a certain position is a probable cause of the backfiring.
Posted on: 2013/3/31 7:31
DHLA 40's
From Sydney, NSW
Hi guys, I have twin Dellorto DHLA 40's on my A15 and the rear carby is backfiring every now and then, but not at idle and not at WOT, mainly when cruising doing about 2500-3000rpm, my first thought was that it could be the rubber seal inbetween the manifold and carby letting air in and leaning the mixture? any thoughts?
Also does anyone know the normal position for the idle air mixture screw, as in how many turns out.
Posted on: 2013/3/31 7:22
