Just curious guys im going to be doing the camshaft on the ute (a15) soon and in doing so it will of course ill upgrade to double valve springs, new light weight push rods and the 312-7.5 camshaft, lifters valves the works..
But what my main question is, is anyone using or have used the Yella Terra YT6023 and is it a high ratio rocker arm?? (A15)
Is it an easy install with out further parts needed and will the normal parts themselves such as the pushrods and the valve spring seats sit correctly with this rocker arm?? or is it better off to just use the normal rocker arm..
I have attempted to find more info on the arm itself but i can't find alot about it even on yella terra itself...
http://www.yellaterra.com.au/products ... entity=4&modelIdentity=24 That and is it really worth the $600.00 for it??
http://www.yellaterra.com.au/products ... productCategoryIdentity=4http://www.ebay.com/itm/Nissan-Datsun ... er-Arms-Set-/330875886899
