Re: Foot well and wheel well
From Goulburn NSW
Hi guys was just walking down the street and sore a bmw with 315/30/20 and they are huge.Now that I have seen them I don't think ill be going that big,265/35/18 on the rear will be plenty and a 165/35/17 on the front.I have bought some space saver 15" with 115/70 and have run it through the tyre comparison calculator and the over all diameter is roughtly the same as the 15"wheels and tyres I was looking at,but decided that I like the low profile tyre look more.
Posted on: 2013/7/2 6:50
From Narellan,Sydney
Yeah pretty sure there the same
Posted on: 2013/6/23 6:29
All stainless steel-mild steel Sheetmetal and tube work
All types of welding
Custom metal polishing
BSA custom fabrication 0415 904 474
From Goulburn NSW
Hi guys are the 1200 ute and sedan front gaurds the same?
Posted on: 2013/6/23 6:26
From windsor, sydney
hey guys im running 16 x 8 GTR forged wheels with no mods to the wheel well and just a trim of the front of the guard with no rubbing at all
jpg  IMG_0635.JPG (83.35 KB)
9512_51c6727878571.jpg 448X336 px
Posted on: 2013/6/23 4:58
WARDMAN ENGINEERING
CNC machining
Race Car Fabrication
Suspension, Brake, Drivetrain modification
TIG welding of all metals
0413 595 627
From Goulburn NSW
Hey guys been doing some measuring have decided to 17x6" with 4.25" backspace and +31 offset,will this work.Fook it take it to tempe tyres and get them to work it out.
Posted on: 2013/6/23 2:27
Edited by mcdat on 2013/6/23 3:16:13
Edited by mcdat on 2013/6/23 3:16:36
Tire rubs on foot well with 7" wide +10 offset wheels with large diameter tires. Even 13" tires can foul. In the straight and with gentle turning there is no scrub at all, but there can be scrub against the footwell in a heavy turn near full lock.
Worn castor bushes won't cause it to rub as it would only cause a problem with the tire rubbing on the front (not on the rear of the wheel weel).
See Modifying Foot Well
Posted on: 2013/6/22 7:15
Posted on: 2013/6/22 7:10
From Goulburn NSW
Hey mate wheres these pictures?have looked but cant find them.Ill be tucking the wheels up under the guard on the rear anyway so that's not going to be a problem.
Posted on: 2013/6/22 4:02
From Brisbane
Hey mcdat, I have 17's on the front and 18's on the back of my ute. I have some photo on here and nissansilvia.com. 18's really fill the rear guards on my ute and with the rim fairly flush and the tyre slightly stretched the inner guard sits on the tyre when it is at a reasonable height. I custom ordered my wheels to suit and ill need some inner guard work to get some clearance so that I can actually drive with them on.
Posted on: 2013/6/21 14:04
From Goulburn NSW
Well guys I have put an 18" on the front off my datto and will need to much work to make them fit,and yes they look dumb.So now ill go 17" front and 19" rear.
Posted on: 2013/6/21 8:51
Edited by mcdat on 2013/6/21 9:13:55
