Browsing this Thread:
1 Anonymous Users
Re: '79 Sunny A15 |
For reliability, I wouldn't suggest a cam or carb upgrade. To get your car running they way it should all you need is a decent tune up. It will be your cheapest option. A clean out of your carby would help a lot and there isn't a lot of mechanical knowledge needed to do this. After giving your carb/fuel pump and lines a clean up, id advise you (if you havent already) to throw some money at your electrics. Spark plugs, plug leads, coil could all be replaced. Rotor button and points also. Checking the timing wouldnt go astray either. Best of luck, and i must add, thats one good looking sunny.
Posted on: 2013/7/23 23:45
Re: '79 Sunny A15 |
From MOOROODUC. Victoria
Nice ride ... luv the colour !
I would go electronic ignition then brakes, suspension before going fast make sure you can stop
Posted on: 2013/7/23 9:33
Red 1200 Coupe (Build: DEMAC's 1200 Coupe) Blue 1200 Ute, CA18DE Auto (Build: DEMAC's 1200 Ute) Green 1200 Sedan (Build: Kermit the beat up sedan) Green Sedan #2 (Current build: DEMAC's 1200 Sedan) Brown 4 door AUTO Sedan for sale...
Re: '79 Sunny A15 |
Sounds like a carburettor AND/or ignition problem to me. The stock a-series in good running order is quite reliable.
To make it more reliable all you need is a thorough service on you engine ignition and carb. Electronic ignition is a useful upgrade and many people will comment about a better engine start and crisper engine operation.
Posted on: 2013/7/22 20:26
Re: '79 Sunny A15 |
Not too shy to talk
so will the stupid thing start first go in the cold if i upgrade the coil and ignition system? pretty much just want it to start first go and idle properly so she doesnt die and embarrass me at the shops ;)
Posted on: 2013/7/22 10:41
Re: '79 Sunny A15 |
If you need a weber 32/36 upgrade setup I have one for sale. Send me a PM if you like. Includes oval port manifold, adapter and carburettor.
Also have electronic ignition upgrade kit for sale. A good strong spark is a must for first upgrade.
Chris
Posted on: 2013/7/13 8:11
Re: '79 Sunny A15 |
Depends what he really means and wants but your suggestion of
"He said more reliable. Adding mods doesn't make it more reliable, just faster as its pushing parts more to their limits. I go for reliable modifications. Just do cam, 32/36 webber elec dizzy And exhaust. Will make it more fun without detracting too much from reliability"
If he said more reliable therefore a cam & 32/36 weber does not make it more reliable than stock cam and carb in any way. There are plenty of cammed, 32/36 and elec dizzie setups that go worse than stock and end up less reliable with glazed bores, bad Nox figures and no mid range ending up with a shorter lived engine that is not even close to its limits.
As for limits, a well tuned A series are proven to be over-engineered reliable so to go further in reliability would mean easier to live with which would mean modern efi with crank angle ignition, quality deep cycle battery, good suitable oil, new oil pump and good cooling system. Well tuned boost with 150hp ate stock internals at below 6500rpm is still way within their limits.
cam 120 32/36 350 adaptor 40 pipes 400-500 good setup dizzie 65-180 Jets 50-120
Posted on: 2013/7/13 7:56
Re: '79 Sunny A15 |
Posted on: 2013/7/13 6:02
Re: '79 Sunny A15 |
You an also consider a bolt on setup that can be removed using your stock maifolds. eg. Toyota SC14 supercharger or IHI SC 1200, 1.75 inch stromberg, brackets and pulleys done by reputable in your area. SC14 or IHI Lyshom 1200cc $500 SU $50-80 brackets $250 pulleys $300-500 water injetion $50 You will make more power & torque than a $3000-4000 dollar NA A15 Poms make 78-100hp atw from 998cc supercharged minis cast iron A series https://www.youtube.com/watch?v=681ftj5iQyohttps://www.youtube.com/watch?v=HqBju8QEgKg
Posted on: 2013/7/13 5:47
Re: '79 Sunny A15 |
Cam, carbies, overbore, flattops, extractors, ports and valves.
Posted on: 2013/7/11 22:21
Re: '79 Sunny A15 |
nice sunny, ive got a 79 sunny shockwave blue.. my fuel gauge used to dip and come back up, i cleaned the contact for the fuel sender, now it only moves if i go uphill or downhill.
Posted on: 2013/7/11 9:45
