Re: WTD Accelerator cabel
From Brisbane Qld
I just found one on eBay from tie land only $33 with postage
Posted on: 2013/9/12 22:06
Isnt it in usa.... factor in postage
Posted on: 2013/9/12 21:34
From Brisbane Qld
Ok I will give it a go cheapest yet
Posted on: 2013/9/12 20:44
You can buy from the site. Click "Add Part" to start.
Posted on: 2013/9/12 19:25
From Brisbane Qld
So u cannot buy from the site?
Posted on: 2013/9/12 9:48
To use the site, pick one of the two products listed. Click "Add Part". Don't ask, it's a catalog - they only have what is listed.
Posted on: 2013/9/12 7:13
From Brisbane Qld
Rockauto.com is the one just looks shorter A bit hard to use that site I u haven't used it before How do I do it? Ask for the Right length?
Posted on: 2013/9/12 5:32
Several companies list the part number. Even the Nismo 2013 catalog lists 18201-H8501. It's not clear what the difference between 18201-H8501 and 18201-H8501 is, probably one is longer than the other (so could fit either use).
Posted on: 2013/9/12 4:18
$5 at rockauto.com. Check the length that you require.
Part numbers from Nissan: 18201-H8502 or 18201-H8501 or 18201-H8802 or 18201-H9160. $22 from Nissan, though that one might be too short for your B310.
Posted on: 2013/9/12 4:11
Google bursons or nissan. Or look at the add you put on ozdat.
Posted on: 2013/9/12 2:49
