Re: weber Question
From Trinidad and tobago
Thanks guys for the feed back the cabby is running lean atm but it performs well,no doubt.
Posted on: 2013/11/20 1:57
'71 Four Door Sedan.
Street Sleeper!
STILL LIVIN' THE 70'S LIFE !!
Re: weber Question
Quite a regular
From neerim east victoria
you could try fitting a "helicoil" thread repair insert, a good engineering machine shop should be able to do the job
Posted on: 2013/11/18 21:03
Re: weber Question
Unfortunately you will most likely have to replace the body as what the problem appears to be is the thread has been ruined.
I think you would be best to replace the unit or replace the body.
Posted on: 2013/11/18 13:49
weber Question
Ihav a weber 32/36 but the only problem that i have with it is the idle mixture screw is mest up.when i push firmly it goes in then threds but the mixture is off an the engine cuts off at that point and when i back off the screw it pushes back out just siting thereOpen in new window
Is there any way of fixing this problem? tap over the hole i noticed that this one has a short screw.
Thanks
Posted on: 2013/11/18 8:38
Street Sleeper!
