Re: Monroe strut insert part numbers similar to golf inserts
OK - sorry for the late reply. I've checked em out and they fit fine monroe 25-3436.
The pushrod of them and the 'proper' monroe strut inserts for the 1200 actually stick out at full extension almost precisely (give or take 1-2mm) the same amount. But the BODY of the 25-3436 ones are 3.5 inches shorter, so with a sleeve on top of them to take up the space in the strut tube, you can get 3.5inch shorter springs (at full droop) and still be captive. Naturally if you only needed (for example) 2 inches less travel at full droop, you could just as easily run a 2 inch spacer on top and a 1.5 inch one below the strut insert. The hollow bar I got is a nice fit too - fits inside the strut tube neatly and also just enough clearance for the pushrod to fit through the centre without rubbing at all.
The very top of the strut pushrod, where the strut top bolts on has similar threaded length, but the 'step' section is shorter on the shorter strut inserts. I have put the spring perch/top and bearing and strut top on one, and due to the way they fit on there, this actually has no effect whatsoever on how they mount up and so on. In other words, if the 'proper' strut inserts had a smaller stepped section, they'd fit just as good too, so I don't actually know why it's there (just copying the originals probably).
So if you have dramas getting the shroter strut inserts, let me know I'll chase down a set from where I bought my last pair (it did take about a week they didn't have em on a shelf, but did get them in with seemingly no dramas) and if you need some pieces of hollow round bar cut to length to suit, let me know as well.
Posted on: 2013/12/13 5:54
John McKenzie
Andy - I may be able to get the monroes - "25- 3436" I've actually got a set here, but I haven't actually fitted them inside the strut tubes to check their fit. I have also gotten some hollow steel bar to cut down and act as a solid spacer so they are a firm fit in the strut height wise. I'm seriously short on time, but I'll do my best to test fit em in a stock 1200 strut (and work out what size spacer sleeve/shim would be needed). The bar was about $80-100 (I forget, I bought it over 6 months ago) for a metre length, so it would end up being about $20 per pair of struts when cut to the right length.
I'll let you know (if I remember!) on the weekend, if I get time to check it, and if not phone or PM me to remind me!
Posted on: 2013/12/3 6:05
John McKenzie
From Armidale N.S.W
Just uploading a list of Monroe part numbers and basic vehicle model description to replace golf inserts as i have had trouble sourcing golf inserts. Please note there is no information in regards to outer diameter that is up to interested persons to find out and the model descriptions have been kept basic. If you go to monroe website you can search each part number and get more details regarding models but didnt see it as very relevant regarding 1200's.
Com = Compressed Ext= Extended
P/N Com Ext Year Model
24-0910 334 mm 491 mm 64-77 Triumph 2000 2500 p1 Stag
24-0915 366 mm 533 mm 69-72 Capri/70-74 Escort (twin cam only)
25-0181 351 mm 509 mm 87-92 Camry/Holden Apollo
25-0341 351 mm 506 mm 8/85-9/89 celica/1/84-12/89 corolla
25-0530 360 mm 499 mm 94-3/03 Daewoo Many models
25-0826 351 mm 501 mm 79-83 golf series 1,3/73-8/83 golf series 1
25-0940 366 mm 525 mm 3/83-86 Camry/vienta SV10,SV11
25-3436 335 mm 525 mm 81-83 Nissan Pulsar N10 3 & 5 door Hatch
25-3655 354 mm 504 mm 82-88 Camira Sedan,Wagon
73229 367 mm 524 mm 84-89 240z,260z,280z,300zx
E3402 371 mm 528 mm 90-10/97 Holden Calibra
E3404 357 mm 504 mm 8/96-8/98 Holden Astra
E3444 368 mm 522 mm 94-96 Saab 900
E3445 368 mm 522 mm 94- 96/96-98 Saab 900
MG-233 356 mm 516 mm 87-92 Camry/Vienta (V6) sedan
MG-242 370 mm 510 mm 87-9/95 corolla AE95
MG-247 371 mm 528 mm 90-10/97 Holden Calibra
MG-947 366 mm 522 mm 72-85/75-84 Lancia beta series 1,2,3 sedans
MG-960 358 mm 511 mm 82-87 Volvo 360
Posted on: 2013/12/2 5:48
73 1200 wagon SOLD
