Re: WTB Datsun A Series Dogleg Box
You will most probably find that $700 including freight is not enough to purchase a 5-speed dogleg box.
I think they weigh 23kilos dry and require the bellhousing to be split from the gearbox to send as two packages. Most postage companies have a weight limit of 20kg.
I would consider $750-$1100 the going rate for the gearbox alone, that is respective to the market I am in. From the states you may have some luck but once again, the freight can be a killer.
Posted on: 2014/2/1 23:02
BUMP
Posted on: 2014/2/1 22:53
UK
Posted on: 2014/1/30 22:56
Shipped to where?
Posted on: 2014/1/30 21:00
Bump
Looking for a complete box with gearstick and xmember
My budget is Max 700USD shipped
Posted on: 2014/1/30 17:12
For the B310 4-speed and 5-speed crossmembers are the same.
However, 56-series and 60-series differ
Posted on: 2014/1/30 1:17
Try and get the gearbox x member too as they differ slightly from 4 speed.
Posted on: 2014/1/30 0:35
Also happy to take a standard non dogleg pattern 5 speed....
Posted on: 2014/1/29 23:50
My budget for five speed is 700USD shipped...
Posted on: 2014/1/29 16:24
From St. Louis, MO USA
I have (2) 63A 5-speed gearboxes with the A-series bell housing. [From the USA 1977 Datsun B-210 with the A14.]
I get $700 USD each for these gearboxes. Peter
Email is best. PeterZekert "at" JUN0 . C0M
Posted on: 2014/1/29 3:47
