Re: How do u remove the handbrake lever and cable from a 1200 ute??
From Newcastle, Australia
Cheers! I'll give it a crack!
Posted on: 2014/6/4 1:14
All while car is safely locked in place with wheel stops
Posted on: 2014/6/3 9:58
From Armidale N.S.W
Undo the 2 bolts 1 either side of lever follow the cable down tunnel to 2 philips head bolts in a bracket holding cable in place get underneath where cable comes through rear of cab theres a u shaped clip holding cable in place remove and slide it all out from in the cabin. Obviously after also disconnecting it from underneath where it joins to cable for rear.
Posted on: 2014/6/3 7:19
73 1200 wagon SOLD
Hey was wondering if anyone out there has removed the handbrake lever and cable completely from the cab of a 1200 ute? I'm having dramas getting it out. Any advice would be appreciated.
Posted on: 2014/6/3 6:57
