Re: Cheap a15 forged conrods
From Sydney
Looks like there is also several rod option for the same engine, e.g different little end dimensions to allow for piston pins, interference fit or floating.
I'm thinking the first one is a typo due to the Center to center measurement is consistent with the A12 rod and is not for the A15
OTOP| Engine model| pcs/set| (mm)c-c| B/E bore| S/E bore| B/E W| S/E W| bolt| Net weight
HCR1249 A15 4 121.5 48 17.4 22.8 22.8 5/16" ?
HCR1293 A15 4 133 48 19 24.3 21.8 5/16" 396-409
HCR1301a A12(J) 4 121.5 48 17.455 24.3 21.8 5/16" 364-376
HCR1301b A12(L) 4 121.5 48 17.5 24.3 24.3 5/16" ?
HCR1373 A13(L) 4 145 48 19.01 24.3 20 5/16" ?
Posted on: 2014/6/25 9:12
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
What are the reviews of that particular product from that company? Is their quality control good?
Posted on: 2014/6/25 8:52
Stock are forged.
H section rods are structurally stronger.
Your alternative is to have your factory rods shot peened or heat treated for improved strength.
Posted on: 2014/6/25 8:17
Are not the stock conrods forged?
In general the h-beam style is stronger and so suitable for high-boost Turbo. Or 14:1 compression racing engines.
Posted on: 2014/6/25 8:09
From Sydney, NSW
Hi Guys,
I came across these which are pretty darn cheap: http://www.aliexpress.com/item/Forged ... acing-cars/616968235.html
There are two listings under a15.. just wondering which were correct? and if these would have any advantage over using stock a15 conrods?
Cheers,
Tom
Posted on: 2014/6/25 7:52
