Re: A series engine with volumetric compressor?
I know we are talking about older Nissans, but the new Nissan Frontier pickups have supercharged engine (VG33E).
Posted on: 2002/10/24 4:33
From LISBOA, PORTUGAL
paul
I am doing fine, I hope that you are great too.
I think that it was a earlyer Datsun (previously to the Micra-March). However it could be only junkyard men talk. Can be just a mith. He talked about exclusive south africa engines.
Ricardo
Posted on: 2002/10/23 12:16
From sydney australia
heya ricardo,how are you.the only supercharged nissan engine i can remember is the ma10 from the nissan march,which,i think,was supercharged & turbocharged.this was a twincam 16 valve 4 cylinder in a very small car.but then you're talking south africa,so i can't say.
Posted on: 2002/10/23 12:01
Hello
I was talking about a stock NISSAN supercharger.
Ricardo
Posted on: 2002/10/22 15:59
From Auckland, New Zealand
Cheers Micko,
Having a look now...
Posted on: 2002/10/21 19:04
#Datopower#
From sydney
Datopower
Have you had a look in the photo section?
main : mechanical : engine : photo 11
Could be a good place to start.
Exhaust in a dato could be a bit tight, the morris has a bit more room around the strut towers.
Micko
Posted on: 2002/10/20 22:27
Hey i'd really like to know about any bolt-on superchargers for A-series.. WICKED!
Posted on: 2002/10/18 20:23
#Datopower#
From Canberra, Australia
Ahh superchargers....
Now I understand...
Posted on: 2002/10/18 10:44
These are not the correct definitions I think, but I will try to explain it:
In a turbo compressor you have two turbines conected between them by a shaft. When the exhaust gases pass by one of the turbine they move it and then the other turbine moves and forces the air into the engine.
A volumetric compressor is mechanicaly driven (by some puley conected to the crankshaft) and it compresses the air into the engine by taking some mechanical power from the engine. In the USA they are called SUPERCHARGERS and the principal type used is the Roots (with two Lobes). In the Europe VW introduced the G compressor some years, but it is not used today due to some wearing problems.
Ricardo
Posted on: 2002/10/18 10:39
Ok I'll put my hand up as the dumb guy...
What is a volumetric compressor?
Posted on: 2002/10/18 10:29
