Re: Where to buy the shifting inserts for the synchros?
From Brisbane
thanks for the info DD
Posted on: 2014/9/18 10:45
2,3,4,5th gear inserts are the same as 4-speeds.
1st & REV inserts are unique to the 60 dogleg.
Nissan sell them. Part numbers are in our tech article.
Posted on: 2014/9/18 9:05
From Brisbane
i'd say it would be the b310 as its a 60 series box
Posted on: 2014/9/18 8:56
It depends on which dogleg you have. 5-speed dogleg from B210, 5-speed dogleg from B310 or 5-speed dogleg from B110. All use different synchro parts.
See Synchros
Posted on: 2014/9/18 8:23
From Brisbane
The lugs that go into the synchro. i think there is 3 of them?
Posted on: 2014/9/17 10:33
From Christchurch NZ
Are you talking about the energizer lugs, or the synchro rings?
The Synchro rings are availabe new from nissan.
However, it's quite common for the journal upon which the ring runs to wear.
Parts from a 60a four speed should work yes. (I've used 63 four speed parts in my 63a five speed before.
Posted on: 2014/9/17 9:58
Forced Induction!
From Brisbane
would the inserts from a 4 speed work?
Posted on: 2014/9/16 10:21
From Brisbane
I'm chasing the inserts for the synchros. where would i get them from? i have a 5 speed dogleg.
cheers
Posted on: 2014/9/15 2:05
