Re: Interesting head gasket
Not too shy to talk
From South Africa
Thanks ddgonzal :)
The OEM A14 gasket I have is oval.
That is why I am asking. Could the OEM GX one be round?
Will be cool if it is for a cheap way to not need to get expensive MLS :)
Posted on: 2015/1/12 8:34
The seller is Bprojects. You can ask him a question. Since it is genuine Nissan GX 11044-H2301, I would expect it to be for up to 79mm bore maximum.
Bprojects web site lists:
* P-E-009 NISMO metal Head Gasket 0.8mm-79.0mm
* P-E-010 GX Head Gasket 0.6mm-79.0mm
Most head gaskets are bigger than the engine bore.
Posted on: 2015/1/11 20:27
Not too shy to talk
From South Africa
Hi members :)
I saw this Gasket
It says 79mm bore. But I think it will be 79mmx77.65mm+- ?
How good will the fire ring cope with 78mm pistons when using a gasket like this?
Regards :)
Posted on: 2015/1/11 14:03
