Re: H190 LSD clutch type mechanical unit
Deposit taken this LSD unit is sold
no more available
Posted on: 2017/11/7 9:37
Edited by D on 2017/11/9 2:39:34
Edited by D on 2017/11/9 22:14:12
Edited by D on 2017/11/9 22:14:33
Edited by D on 2017/11/11 4:16:54
Last one at 660aud all inc. delivered
29 spline ready for install into your chosen ratio
Posted on: 2017/10/21 0:12
PM me for any further questions
Posted on: 2017/10/11 9:29
Edited by D on 2017/10/14 6:33:07
Edited by D on 2017/10/21 0:13:13
quoted from link above post
""H190 into my ca18 1200 coupe as I have not had any luck sourcing a R31 BW LSD diff to shorten
It is 20mm wider in track 28 spline axles and weighs in at 42kg compared to 34kg H165. Im now on the look out for an LSD center.""
2cm longer each side nice with flares :)
last one guys and will make the most affordable lsd conversion
that almost weighs halve of the r31 setups
Posted on: 2017/9/12 16:51
last H190 LSD clutch pack unit 8.5kg posted
the other one went to Denuto in victoria
You can use bluebird complete diff without shortening
if you use the right fwd style offset wheels for it
There is also a datsun 1600 wagon h190 that is only 16mm
wider than the H165 and link below states that the bluebird
H190 diff is only 20mm longer than h165 1200 ute diff
3.900 910 Series 2 Bluebird 29 spline (CA20 engine)
910 Bluebird Wagon (sedans used H165)
3.889 S12 Gazelle AT
3.700 S12 Gazelle MT
4.111 C20 with Z20 engine MT
4.3 C20 with Z20 engine AT
4.111 Vannete 29 spline
http://datsun1200.com/modules/myalbum ... &com_order=1#comment11596
h190 above h165 below comparisons
Posted on: 2017/8/24 17:32
Edited by D on 2017/8/27 13:31:05
Edited by D on 2017/8/27 13:32:08
still available
Posted on: 2017/7/30 12:48
one sold
last one for 58,800 yen 680aud
paypal takes 2000 yen (26 aud on my end)
Posted on: 2017/7/16 3:26
Edited by D on 2017/7/19 3:39:07
Edited by D on 2017/7/19 3:40:44
Edited by D on 2017/8/15 13:45:24
Edited by D on 2017/8/15 15:08:47
There are no extra customs or tax costs using japan post
Posted on: 2017/7/8 3:53
Edited by D on 2017/7/10 2:55:19
Edited by D on 2017/7/10 2:57:01
Edited by D on 2017/7/11 2:46:08
Edited by D on 2017/8/15 13:48:38
From Beautiful Sunny (sic) Melbourne
PM sent
Posted on: 2017/7/7 14:26
Im almost giving away my last 1 x 720 sourced LSD unit
Ring and pinions are gone so 680 to your door all inclusive.
I sold my prince skyline gt project I was so keen to start that
made way for some farming land.
PM me for any info
EDIT now only one
Posted on: 2017/7/7 13:55
Edited by D on 2017/7/12 13:17:22
Edited by D on 2017/8/15 13:48:08
Edited by D on 2017/8/15 13:48:21
Edited by D on 2017/8/15 15:07:00
