Re: whats to know about brakes
Thanks guys :) ill do that this week hopefully
Posted on: 2015/4/25 2:18
From Melbourne, Australia
I passed engineers pedal force and repeat brake tests with 11/16th and no booster. Hilux 4 spots on front and skyline discs rear. Engineer was not keen cause he thought too small but said he was willing to see if it would pass cause I had already been running the setup for a couple of years and also run similar on the rally car.
Posted on: 2015/4/24 13:58
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Its about what your engineer requires, so best to ask him. Some guys here use stockers with success. The larger masters requires more pedal effort, though some guys like that.
Posted on: 2015/4/24 12:07
From Perth
B310 brake master 13/16"
S13 Silvia master cyl 13/16
R31 master cylinder 7/8
So if you went to a 7/8 master you'd be more than safe in theory
JB1133 master cyl is 7/8 twin bottle and should do the job
Just remove the residual valve to the rear brakes so the rear discs don't hold on
Posted on: 2015/4/24 11:21
You sure my engineering guy said i need to upgrade it to compensate for bigger brakes
Posted on: 2015/4/24 4:21
Use the B310 disc brake master. B310 also comes standard with automatic proportioning valve.
Posted on: 2015/4/24 1:47
Ok so I have a datsun sunny b310 sedan with a ca18det. I am getting an r31 diff cut down and i have s13 brakes on the front im a little confused on how to determine about brake booster master and portioning valve.
Posted on: 2015/4/24 1:30
