Re: DATSUN 3D AUTO PARTS bike carburetors superchargers turbos efi
From Creswell, Oregon USA
Whats the quote for casting?
Posted on: 2015/5/20 16:06
An idea doesn't work unless you do.
Instagram @MD_Machine
Parler @MDMachine
From Adelaide
Those prints look pretty good, what printer are you using? We use an Ultimaker 2 at work, I have a Prusa Mendel at home which works alright but is not as precise as the Ultimaker.
Posted on: 2015/5/20 8:30
1200 Coupe A15E - ITB
Lamb Daiquiri - a man's cocktail!
Manifolds printed
jpg  quad 01.jpg (11.10 KB)
15999_555c315c0e1ef.jpg 700X394 px
Posted on: 2015/5/20 8:01
Drawings done for simple quad bike carb setup, will print soon and design the linkages once the carbs are sitting in the engine bay
jpg  dtc2.jpg (15.78 KB)
15999_555b0106419f0.jpg 700X617 px
Posted on: 2015/5/19 10:24
From Adelaide
Depends on the plastic, ABS is not so great with petrol (paraffin solvents), PLA is not so good with ethanol (alcohols). You could paint it with an appropriate epoxy. PLA softens at 60-70°C so not really suited to that type of job. Which is why I'd say supercharger said he'd get them cast.
Posted on: 2015/5/18 21:09
How well does the plastic hold up to fuels?
Love the idea of printing intakes that would otherwise take some expensive machine work to accomplish.
Posted on: 2015/5/18 16:01
Parler @MDMachine
DD,
ECU is just in case he uses kits for later cars as there are now plenty of metro kids with little fwd rides that want a simple kit for boost. I Agree keep it simple, keep if for us and keep them carby.
Sounds like a plan, the mini manis would be small and easy to sell in japan for cheaper than those rip off versions. Yeah sorry those chargers are ogura tx.
Posted on: 2015/5/18 10:02
As far as I know there are no Japanese kits for amr500's, the ones you mention are not for amr's
I like designing with parts that are readily/cheaply available. The bike carbs im using are 34mm, so they are ideal for twin/triple or quad setups.
Adapters allow for cheap setups as you retain your standard factory parts, manifolds...etc
Any setups are a possibility....adapters/manifolds...etc using whatever parts are available.
You want it, there's a good chance I will consider producing it
Posted on: 2015/5/18 7:01
Edited by supercharger on 2015/5/18 7:17:09
Why would an ECU be a challenge? Bike carburetors don't use an ECU.
Posted on: 2015/5/18 5:33
What kind of plastic is the adaptor? Fuel resistant?
Posted on: 2015/5/18 3:58
