Re: L20b into b210 120y swap advice needed
From sydney australia
Have recently found that R30 Skyline engine brackets are shorter than 200b/Stanza/Bluebird, by about 25mm/ 1 inch. I haven't tried them on a crossmember yet, but this should give me enough clearance on the bonnet with my Sunny. Pity it's from such an old/rare car. I hope the sump doesn't hit the crossmember, in fact. They look easier to duplicate in plate steel, as well. I've been told the 120Y has a taller nose than the Sunny, but it's always nice to get the engine down as low as possible.
Posted on: 2015/9/28 23:27
Thanks for that, i am trying to avoid notching the crossmember if I can haha..
Posted on: 2015/9/26 8:00
From Brisbane, Australia
zakdat wrote:
Hey all
I'm looking at doing an l20b swap into a b210 120y
Just wondering what crossmember and pedal box/ clutch setup to use
And if anyone has experience or tips on doing the swap
Thanks in advance
Use the 120Y pedal box. The 120Y has the studs in the firewall for mounting a clutch master cylinder in the engine bay already. You just need a holesaw to cut the center hole to suit, then drill the clutch pedal to fit the rod. Couldn't be easier! I used a 240Z clutch master cylinder.
Best way is to use the 120Y x-memer imo. 180B x-member makes more problems than it solves. Some photos and info on my L20B B210 conversion here:
http://datsun1200.com/modules/newbb/viewtopic.php?topic_id=59849&viewmode=flat&order=ASC&type=&mode=0&start=43
Posted on: 2015/8/15 23:42
Use the stock crossmember and a front-sump 810 oil pan
Or use a 510/610 crossmember and a mid-sump 510/610 oil pan
For more tips see L-series Engine Swap
Posted on: 2015/8/15 5:06
Hey all
Thanks in advance
Posted on: 2015/8/15 4:45
