(1) 2 3 »
Re: What head is this?
The ports are smaller, flow less air. And you lose about 1% because they are a non-quench head.
* H89: 82 hp stock @ 6000 rpm
* H62: 75 hp stock @ 6000 rpm
The H62 (1974 A13 head) will presumably make more torque at low RPMs (say 2000-3000 rpm). So for an A12 may be better for in-town driving than A14 head, yet with more pep on the highway than a standard A12 head.
Posted on: 2015/12/3 2:12
How would it perform up against the likes of a H89 head? on an a12...
Posted on: 2015/12/3 1:53
It's a good head for an A12.
Was 75 hp ouput without having to rev higher than stock.
Posted on: 2015/12/3 1:24
Yeah dd just measured them mate, they are 28x30 as you said.
Posted on: 2015/12/2 22:51
Based on the info we've got so far, it could be a 1974 A13 head:
* Only head known to have 28x30 mm intake ports
* A rare piece, only sold in USA for one year
GG-DATSUN, what are the exact measurement of the intake ports?
Posted on: 2015/12/1 11:44
So what did you want to know? It's not a performance head, it's a smog head
Simple question from gg-datsun.And im also interested in finding out also..
So What head is this??
Posted on: 2015/12/1 10:22
It is same compression as a regular head.
* A-series varies compression by CC of piston dish
* L-series varies compression by CC of combustion chamber (and dish)
The open chamber gets rid of quench. Quench causes temps to spike and thus more oxides of nitrogen (NOx).
Posted on: 2015/11/30 12:18
From Mordialloc Victoria 3195
Being an Open chamber - lower compression ? - possibly could use it for a turbo application ?
Posted on: 2015/11/30 11:30
keep it simple
All GX heads have extra large oval ports, water holes below the ports, and closed chambers.
The one here is an open chamber head (the opposite of a heart-shaped combustion chamber). As far as I know, open chamber was not used for the 120Y. So what did you want to know? It's not a performance head, it's a smog head. Will work OK for a 1200cc engine, but prone to run-on (dieseling) unless the carburetor is carefully adjusted.
Posted on: 2015/11/30 5:45
I think I have attached the correct photo this time? I have pulled apart plenty of 120y motors before without finding a head like this. And no it is not ported at all. I think it could be a gx head of some sort?
jpg  12312147_10207919559764292_94901075_n.jpg (92.22 KB)
11906_565bdf5dc40ee.jpg 960X720 px
Posted on: 2015/11/30 1:23
Edited by GG-DATSUN on 2015/11/30 5:32:22
(1) 2 3 »
