Browsing this Thread:
1 Anonymous Users
Re: Additional shock info |
Not too shy to talk
From Victoria, Australia
Recently discovered a friend has used Commodore wagon Bilstein rear shocks on a Corolla (KE20) rally car with good reports
Posted on: 2015/11/30 10:01
Not too shy to talk
Bilstein 24-003179 will fit rear B210 sedans. Also will fit early RX7. 12.70" collapsed, 20.16" extended
Bilstein 24-001540 will also fit and is similar size. A friend has these on his 1600/510 sedan. I think these are to suit an early Corolla and '80's Mazda 626. 13.82" collapsed, 21.77" extended
Bilstein 34-184530 is the front VW Rabbit/Jetta cartridge insert part number. 15.12" collapsed, 19.74" extended.
Google part numbers for prices and additional info
Posted on: 2015/11/28 3:35
Not too shy to talk
The RX7 S1-S3 rear KYB Gas-A-Just shock is now very hard to come by as it appears to be no longer available, shelf stock only. Even the U.S. sites don't seem to have much.
Posted on: 2015/11/28 3:13
Registered Users Contentmaster Usermaster
Yes, KYB was original equipment on Datsun 1200s. Their oil shock is the best one for stock 1200 springs and light wheels, has the best control.
As you point out, for heavier suspension, a stiffer shock is needed.
Posted on: 2015/11/28 0:59
Not too shy to talk
Hi all. I have a 120Y B210 sedan and have been gathering some shock info from various sites. Somebody can update the Wiki if they like. Some of the info is existing.
Front KYB Z31 front part number is 365056. It's not a mono tube shock (Gas-A-Just NLA) but it has apparently 50% more rebound valving than say a Datsun sedan shock. Probably only for 2" struts. It's shorter so will need shortened struts or spacers. Reported to work best with 250lb springs, which is getting up there for a little 1200. 200lb apparently is a little soft for the shock.
Rear KYB Gas-A-Just 553295 Designed to suit 510/610, Torana, Cressida etc Will fit 120Y/1200 sedan as it's the same stock length. If leafs are reset you may want shorter shocks. This is a mono tube shock (like Bilsteins) and is reported to be excellent value for money and offer great performance. Suits sedan only as utes and coupes are shorter.
Prices can be easily found via eBay.
Commodore wagon rear from VB to VS are also around 505-517mm extended and have the same type of mount (not sure of bush diameter though). These could be ok if the valving suits.
The '68-'69 Camaro rear option is reported to be very over damped for a Datsun, even the cheapie shocks are reported to be too stiff for general use. Adjustable AGX versions have been used on some Datsuns and only the bottom three settings are usable. Not a preferred option.
I am personally a fan of Bilsteins but I have heard excellent comparison reports from Baz at Datsport on the other Datsun site. KYBs are reported to be better value in some regards as the valving works out of the box. Bang for bucks you would have to import Bilsteins from the U.S. and they would be nearly twice the price as locally sourced KYB's, and valving may need a tweak to suit your application.
Hope this helps somebody and refreshes the memory.
Posted on: 2015/11/27 22:46
Edited by Robby on 2015/11/28 3:39:04
