Re: Brake,rotor assemble
From Adelaide
MADDAT make many different kits for the front of the 1200.
On my maddat hubs the brake rotors go on last over the studs
and are held in position by two small screws and then the
wheel rim once fitted.
jpg  sus parts 1 .jpg (159.00 KB)
10466_57724a1e43836.jpg 820X461 px
Posted on: 2016/6/28 10:58
Go Fast,
Or Go Home.
Omg
Posted on: 2016/6/25 10:21
Car free
From Narellan,Sydney
I'm sure maddat will assemble and pack bearings ready for fool proof install.prob best to let them do it if your asking these questions mate
Posted on: 2016/6/25 4:29
All stainless steel-mild steel Sheetmetal and tube work
All types of welding
Custom metal polishing
BSA custom fabrication 0415 904 474
I would expect the hub in a "front end" kit to be assembled with bearings. But maybe not
So it could go either way
Posted on: 2016/6/23 9:06
From Goulburn NSW
Regarding Maddat setup I just assumed that because it said in their description new bearing's that I would have to assemble like the diagram.
Posted on: 2016/6/23 8:56
The Wilwood diagram above looks like a rotor that doesn't use a hub. Instead the wheel bearings go directly into the rotor -- like large Ford or GM cars
The bearing pieces differ slightly from most Datsuns, which don't use #13 (spacer) if I recall correctly
jpg  14333_576b79677cf5d_.jpg (34.90 KB)
174_576b9511c1e70.jpg 576X372 px
Posted on: 2016/6/23 8:47
Maddat sells four front brake systems for the 1200? Most of them look like they use bolt-to-the-hub rotors
S13/S14 type brakes don't use bolt-on rotors. Instead you install the hub, then slip the rotor over the hub. It's not held in place until the wheel is bolted on
Posted on: 2016/6/23 8:40
From Goulburn NSW
Hey DD,
should of mentioned,complete aftermarket Maddat front end.
Posted on: 2016/6/23 8:07
As far as the rotor goes, there is no assembly -- the brake rotor is one piece with no bearings. It bolts to the back of the hub with four bolts
Hub
Rotor bolted to hub
Posted on: 2016/6/23 7:56
From Goulburn NSW
Hey guys,
just surfing the net and looking for diagrams on how to assemble the rotor's to the struts,when I get to that stage.Would the below diagram represent a basic overview on how it all goes together?
jpg  Rotor daigram.jpg (141.33 KB)
14333_576b79677cf5d.jpg 700X611 px
Posted on: 2016/6/23 6:54
