(1) 2 3 »
Re: Is it legal or not legal
I recommend the stock shifter, it works very well
* Examine the bushings. If damaged, fit new ones (about $10 from Nissan)
* A new shifter knob (about $40 off eBay)
Posted on: 2017/2/15 4:12
From Biloela, Sunshine State
Ha, cheers DD. Doing a full resto for my first Datsun (120y) and both of my gearboxes don't have the pattern. One is missing the knob and one has it worn off! Are there any good suggestions for shifters? Preferences etc?
Posted on: 2017/2/15 3:30
Just print this out, and tape it to the ashtray. No fear
photo 26585
Posted on: 2016/10/15 4:15
From Narellan,Sydney
I think the pattern sticker should be the least of any modified cars problems lol.anyway how's your beast going mcdat?
Posted on: 2016/10/14 2:46
All stainless steel-mild steel Sheetmetal and tube work
All types of welding
Custom metal polishing
BSA custom fabrication 0415 904 474
From RSA
dude are the cops giving you a hard time --- In south africa we have a solution for every problem --- just a pkt of smokes and a bottle of cheap wine --- make sure you give him shooting lessons lol https://youtu.be/xC_VVWA36ZM
Posted on: 2016/9/23 17:33
Wait, on that last quote it only says that it has to be "displayed in view of the driver at all times", so you could technically have a sticker anywhere as long as you can see it? As in hide it on the dash? (small but visible)
Posted on: 2016/9/23 12:24
New Zealand was the original report
Australia was the question - they give tickets for it!
United States Federal Motor Vehicle Safety Standards
49 CFR 571.102 - Standard No. 102; Transmission shift position sequence
S3.2 Manual transmissions. Identification of the shift lever pattern of manual transmissions, except three forward speed manual transmissions having the standard "H" pattern, shall be displayed in view of the driver at all times when a driver is present in the driver's seating position.
Posted on: 2016/9/21 4:36
From Las Vegas USA
Dave is that a Fed reg or California?
Posted on: 2016/9/21 4:30
In my country, Automatics are exempt from the labeling requirements. But with Australia being as litigious as it is, I'd use the same labels as the car the gearbox came out of. That's usually printed on the shift knob or on the shift panel/shift console
Posted on: 2016/9/21 4:07
From Goulburn NSW
Hey guys,
so if im running a sequential shifter i'll have to display the pattern for that,which is pull back and push forward.
Posted on: 2016/9/21 3:09
(1) 2 3 »
