Re: Cutting out radiator support to make room for thermo fans
From St. Louis, MO
Nice, thanks for the pictures as I'm about to do the same
Posted on: 2016/12/30 17:51
Puerto Rico! Home of the fastes Rotary engine cars! Period
From Snohomish, WA USA
No picks at the moment. My car is apart. I have a second 4" fan where the AC opening is. That's the area that I cut out.
Posted on: 2016/12/22 3:49
'73 2 Door Sedan
Crower Stage 3 Cams/SS Valves
Forge CP Pistons/ Eagle Rods
Ford 8.8/Mini Spool/4.11
From Newcastle, Australia
My other option is leaving one fan on the front and mounting the second in pull configuration on the rear of the radiator. It's snug but does fit. Just a bit ugly!
Posted on: 2016/12/21 5:53
Hey Ernie, did you put the 2nd fan between the radiator and the grille? Got pic? Your 400hp engine must use a large radiator
A single 12" or 13" fan will cool an A12/A14/A15 engine
Posted on: 2016/12/21 1:28
I tucked a fan out front of my larger radiator inside of the radiator support as well. When looking at the engine on the left, also cut out the sheet metal out front to allow more airflow.
You may not need a second fan if you do that.
Posted on: 2016/12/21 1:22
'73 2 Door Sedan
Yes, it would flex too much. Instead of cutting the Radiator Core Support, cut a larger radiator opening in it, larger than the stock hole
Here's one that's been widened about 50%
By the way, the stock A12 fan is more than 12 inches. A 10 inch fan would be too small
jpg  Stock Radiator Opening.jpg (93.75 KB)
174_5859d82c25177.jpg 1024X765 px
jpg  S13 Radiator Opening.jpg (92.81 KB)
174_5859d838a248a.jpg 1024X765 px
Posted on: 2016/12/21 1:17
I've installed a larger radiator and had 1x10 inch thermo fan mounted in to the old radiator support. Unfortunately this isn't providing enough air flow so looking at installing another. My question is how much does the front apron flex with the stock radiator support removed? Will I need to weld in additional support along the top of the apron to compensate?
Posted on: 2016/12/21 0:38
