Im looking for part number for 910 strut inserts
Here are the part numbers for 910 strut inserts:
USA Datsun 910 (1981- Datsun 810/Nissan Maxima)
* 56110-F5125
* 56105-W3725
These are different from USA 280ZX strut inserts. However the 280ZX and the 910 are using the same platform so they are similar. Further, you can use any 2" inserts for Nissan, Toyota, etc as long as they are short enough to fit in the tube and have an appropriate size shaft. For most you need a spacer in the bottom of the tube (e.g. large flat washers)
Aftermarket struts (generically valved) like:
* KYB 365013
* Gabriel G44869
are probably stiffer than genuine 910 shocks, but that might be a good thing if your 1200 has stiffer than stock springs or heavier than stock wheels/tyres
By the way, Nissan model series 910 was sold in USA as Datsun 810 (1981) and Datsun Maxima (1982-1984) which may help when searching for parts -- and most stores list these under Nissan
