Re: A12 turbo
Multi layer gasket was used for 1971 Datsun 1200 GX engine, but maybe the middle layer was not steel? It was very thin
Posted on: 2017/11/1 5:28
Re: A12 turbo
You can get the head O-ringed as well and use stock head gaskets
but not sure how better or cheaper MLS is versus older solutions.
Posted on: 2017/11/1 4:42
Re: A12 turbo
Also are all a12 engines the same? I got one from a 120y to rebuild
Posted on: 2017/10/31 11:04
Re: A12 turbo
Thanks guys
Posted on: 2017/10/31 8:55
Re: A12 turbo
From Mordialloc Victoria 3195
Posted on: 2017/10/30 20:37
keep it simple
Re: A12 turbo
I wont be running more than 10 psi. Where can i buy stronger head studs?
Posted on: 2017/10/30 10:07
Re: A12 turbo
Hey leigh - No problem on the turbo ute as it runs 10psi.
Im getting parts together to build a 15psi+ version to go in the Clubman 7
so I'm just upping everything I did on the last one
dp
Posted on: 2017/10/30 0:30
keep it simple
Re: A12 turbo
From Melbourne Vic
i dont think an MLS is necessary unless youre running big boost. head studs are definitely a good idea though.
ziggy, have you had dramas with the a15 efi turbo?
Posted on: 2017/10/30 0:03
CA18DET 1200 lagwagon retired
LAG510 - SR20DET 1600 sedan
1000 wagon daily - A series magic
Re: A12 turbo
If you're looking for MLS gasket, Bprojects sells them for A14/A15
For copper gasket, Cometic custom order will do
Posted on: 2017/10/29 22:56
Re: A12 turbo
I'm also looking for boosted head gasket options but couldn't find A series head gasket on there website
Posted on: 2017/10/29 21:21
keep it simple
