Re: Rims to suit
From Nyngan, nsw Australia
Excellent thankyou... got something to go off
Posted on: 2018/1/24 11:30
living is good,.....
Re: Rims to suit
Hmmm ... looking at this diagram suggests you might need even less offset + flares. On my 1200s I measured the "back measure" at 89mm. Which is less than 1/2 of a 195-width tyre
jpg  FA-front_measure.jpg (54.04 KB)
174_5a67cb7ec8a30.jpg 400X544 px
Posted on: 2018/1/23 23:53
Re: Rims to suit
No. Probably no issues in the rear, but in front the tyres will hit the strut/spring. To fit 195mm wide tires requires about +15 or +20 offset. Or you could use spacers. Either way 195s in the front will be very tight with stock fenders/guards. But is doable. You might also need to modify the footwell or pull the tires forward (extra castor)
Posted on: 2018/1/23 23:34
Re: Rims to suit
Rubber 195/55
Posted on: 2018/1/23 20:41
Rims to suit
Fulla’s
Q: will 15 x 7.5, 35mm offset fit under Datsun 1200 with no probs
Posted on: 2018/1/23 20:40
