Browsing this Thread:
1 Anonymous Users
Re: ute diff |
From christchurch NZ
sorry if this makes no sense but i put it in the wrong place [see below] then go to roadstar ute diff. p,s so much for figjam huh!
Posted on: 2003/3/26 7:38
ute diff |
noisy ; its ok when accelerateing but when you lift off it clonks, so i put in the other ute diff i had. I had it in my 2 door sedan so it'l fit any sedan will need 2 be modify'd for a coupe comes with driveshaft and will fit a 1200. doesnt have brake pads or drums but you can use 1200 ones as theyre the same hope this helps
Posted on: 2003/3/26 7:33
