Re: Difference In Utes?
On the subject of differences, what diff does a 74 or 75 ute have? All the 1971-1973 utes had the H145, right?
My Japan parts book shows all 1976 and newer B120/B122 as having the H165. Does that seem to fit Aussie utes too?
Posted on: 2004/3/12 17:02
From Sydney, Australia
I've pulled my speedo apart, and reset the miles years ago. It's not hard. I bet if you pull it out, and run a drill on the speedo (in the correct direction), youi'll see what's bent or broken to stop the odometer ticking over. Try and roll the dial over by hand. Worst case scenario is find another speedo. Sounds like you've fixed it how many Japanese would like it to come from the factory...saves them tampering with it before exporting it to Australia on the grey market.
Ther best way to figure out your diff it to do this...Jack one rear wheel up in the air. Put a piece of tape on the sidewall of the tire. Put gearbox in neutral, Put another piece of tape lengthwise on the tailshaft. Get someone under the car, to count the number of times the tailshaft turns for each rotation of your wheel (Which you turn exactly 10 times). This is nearly impossible on a FWD car.
Divide the big number by the small number and you'll get your ratio.
Good Luck.
Chris
Posted on: 2003/5/9 12:44
From Tas
Yep. You are right. My ute has a build date of 7/85. It is interesting to note as well that it has no datsun badging on it - all Nissan logo's.
Not sure what else they may have changed mine has retractable belts, park brake light on top of dash, tacho, disk brakes etc.....
As MadTimo asked (sorry about the car by the way) how do tell what diff is in it??
Also my odemeter has stopped working. Speedo still works and the "meters" dial still works but nothing else. Is this common - can it be repaired?
Posted on: 2003/5/9 12:09
I think they stopped selling the B120 ute in Oz in 1985 or 1986. Anything newer in OZ, is most likely a South African import.
Maybe that's why '86 ones are difficult to find. Maybe they only imported a few.
Chris
Posted on: 2003/5/9 8:48
From Brisbane
ok well then that is most likely right... its just i never come across a 86 1200 ute .... might be rare to get a 86 oz ute
Posted on: 2003/5/9 8:44
OLD SkOOL POWeR!!! [color=CC0000]"with the sound & smell of twin 40s at full throttle!!!" [/
According to Nissan Global, the B120 was made from Feb 1970 to 1986. The B122 was made from Nov 1986 until 1994. It doesn't list the B140 ... so it's hard to say exactly when different countries switched.
Posted on: 2003/5/9 8:34
From Brisbane
the Aussie Utes (b120) stoped in 1985
Posted on: 2003/5/9 0:24
From Sydney
thanks for all the info so far guys,
can anyone tell me what year the B120 ended? because i love the style of the original utes
Cheers,
Tom
Posted on: 2003/5/8 23:25
I thought all utes had the H165 diff. Mines a 1974 model, how can I tell if my diff is a H165?
Posted on: 2003/5/8 16:03
Datsun 1000 ute - Building (slowly)
Datsun 1600 13B turbo - coming soon
The B122s are the newer Japan models (after 1986 I think). The square headlights came in around 1989. They still used the A12, but some had 5-speeds.
The B140s are from South Africa.
The Aussie utes had a big change with the H165 differential (no one seems to know which year this changed).
As with the sedans and coupes, the motor mounts changed in 1974 to the "A14 style", even though the motor is the A12 (A12s?)
Posted on: 2003/5/8 8:06
