Re: fuel pressure
We're running a Holley Red Pump feeding 2 44mm Mikunis at about 4psi, which seems about right.
The biggest problem that we've had is supply to the pump---we ended up using 10mm tube from tank to pump to fix the problem.
Just remember, if you've got too much pressure drop, the fuel will vaporise in nothing flat, even in moderate temperatures.
Posted on: 2003/9/18 1:46
Re: fuel pressure
From Little Rock, AR
I'm using twin 40 Dellorto's, a Holley Red pump and external Holley low pressure regulator set at about 2.5 psi. For a while I ran it between 3 - 4 psi, it ran pretty decent. But when I backed the fuel pressure off to 2.5, I noticed an increase in power, so I think 2.5 is a good pressure for Weber/Delloroto's...of course it depends on your jetting too. You can cheat rich jets by backing the fuel pressure off a little more, or run a little more pressure if you're running lean.
Posted on: 2003/9/17 14:27
Re: fuel pressure
From Melbourne, Australia
are you serious or are you talking bout putting a set of vice grips on the line?
you like running rich????
that sounds a bit odd to me
Posted on: 2003/9/17 13:08
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Re: fuel pressure
From Tassie, Australia
You dont have to run a regulator. I have a large Weber down draught on my Ford ute and an electric fuel pump that pushes about 7psi. It runs a little rich ofcourse but I have no drama with too much pressure, actually has a nice pop pop sound when you back off the go pedal or change gears.
If you cant afford a regulator then you can make a nice simple one that is effective and will cost you very little.
Simon
Posted on: 2003/9/17 13:04
Re: fuel pressure
not on a downdraught weber (32/36 ect)
depends if you go for an elec pump or standard pump obviously, cause if elec pump has over 5psi then yes
Posted on: 2003/9/17 12:57
1200 Coupe Rallycar
Re: fuel pressure
From Brisbane
with my 40mm webers i am running 2psi i think or maybe 2.5psi
got told the mech fuel pumps run anywhere bettween 2psi to 5psi, depending on throttle ,so when at max (5psi)throttle this could knock the needles in your carbs of thier seats
Posted on: 2003/9/17 9:42
OLD SkOOL POWeR!!! [color=CC0000]"with the sound & smell of twin 40s at full throttle!!!" [/
fuel pressure
From durban, south africa
ive read up on sites that you should run a pressure regulater when running a webber carb. is this true? what are you guys running with your webbers?
many thanks
nicholas
Posted on: 2003/9/17 8:13
VW chassis
fibreglass body
A-14
280 cam
ported head shaved 1.5mm
extractors with 2inch s/s pipe
webber 38 dgas.
to come........
Dellorto 36 drla
turbo
and then maybe some gas
