Re: ca18 into gazelle
From Millgrove Vic OZ
Ive just gone throught the IRS 85 Gazelle CA18DET swap. Its pretty straight forward if you use the matching box for the DET. AS Chris said tailshafts are different and needs to be shortened
We swapped the full loom and dash from the donor S12 as well (Big job but not necessary unless you want the boost gauge dsah and full instruments).
Posted on: 2003/10/2 21:56
Cheers Feral
From T'ville
was in the process of replying last night when i got booted off
if you got a inj. manifold and did most of the work yourself prob $2200
Posted on: 2003/10/2 15:12
From Melbourne, Australia
yeah understandable, but hey if you struggle to sell (im seriously doubting it)
im always here
just out of intrest - does the direct fire ignition use a crank angle sensor instead of the conventional dizzy?
if you exlain how thats setup and maybe even estimate cost to setup that would be good
cheers
Posted on: 2003/10/1 15:21
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From T'ville
i dont think it wise to part it out just yet.nice factory inj.wolf3d comp.direct fire ign(no dizzy)vl pump , alloy surge tank.mmmm
Posted on: 2003/10/1 15:17
would you consider selling the injection seperate???
i could justify that for my rallycar
Posted on: 2003/10/1 13:48
1200 Coupe Rallycar
From T'ville
I hear you , been there,stay focused and you'll see a light at the end of the tunnel
cheers
Posted on: 2003/10/1 13:11
i want the sunny, but im broke and jobless (uni bum), so count me out
Posted on: 2003/10/1 13:03
1200 Coupe Rallycar
From Sydney, Australia
The SR20DET would be a good conversion, but a CA18DET would be a very easy modification. For strength, use the CA18DET gearbox too.
Unfortunately this will mean getting a new tailshaft..The front Uni joint is almost certainly different. It's hard to find Gazelles that are low in rust or rust-free. It's Nissan's equivalent to the AE86 Sprinter.
Chris
Posted on: 2003/10/1 12:45
ca18 into gazelle
From T'ville
does the ca18det bolt up to the ca20e gbox/ are all ca20e gboxes the same?(pintara,b'bird,gazelle?)
I'm looking at a new project, a '85 S12 gazelle! and keen for a convert.
anyone want a injected b310?
Posted on: 2003/10/1 12:23
