(1) 2 3 »
Re: New motor for the sunny??
All the "L" series engines were prefixed with an "L" They were found in both 4 & 6 cylinder form & all are single overhead cam engines with a chain drive to the cam.
The smallest one that i know of was the L14, but i have a funny idea there might have been an L13. The odd one out is the L20b, which is a 4 cylinder. It became necessary to use the "b" suffix as there was already an L20, which is a 6 cylinder. The number is the engine dicplacement in Litres. By placing a decimal point after the first digit, it becomes obvious.
The L16 was used here in the popular Stanza range & in the classic & VERY popular Datsun 1600, otherwise widely known as the model 510.
"A" series of engines are the smaller, overhead valve engines that were made in capacities from a nominal 1000cc up to 1500cc Both series are GOOD engines.
Chris
The two of them bear no real resemblance beyond being 4 cylinder inline types.
Posted on: 2003/11/13 10:50
From Perth W.A
an L16 engine is found in the datsun 1600 (510)
it is a little like the A series motor but not
it is part of the L series.
that sounds stupid but it isn't, they sorta look alike.
Posted on: 2003/11/13 10:17
120y Coupe
120Y coupe Race car (SOON)
120Y Sedan for the Lady
From Melbourne, Australia
what is a L16 eng
Posted on: 2003/11/13 9:20
From sydney australia
the gazelle h190 diff is not a bolt in,the bottom suspension mounts are at the wrong angle,& forcing them to fit would cause binding in the rear suspension,something to be avoided.believe me,i've looked & looked & cursed & swore & it still didn't make a difference.the bottom mounts can be changed to suit,so don't give up totally,but it needs to be done by someone whose a competent welder.a stanza h165 diff is a bolt in,& should live behind a stock sr20,but not a turbo one.
Posted on: 2003/11/13 7:34
From Brisbane
Can anyone please list the parts that we REALLY need for SR20DE or similiar conversion? this would help us avoid those scams
I'm doing this conversion pretty soon I'm just looking for someone to do it.
Thanks in advance
Posted on: 2003/11/11 21:08
Not too shy to talk
From Dunedin, New Zealand
My sunny is the square head light model, have a look at my pic's. ive been told basically the whole front end of a 180sx with a CA18 wud go straight on, of course i would need new engine mounts and crossmember but wat about suspension struts etc? also ive been told that a silvia diff bolts straight on? am i being taken for a ride|??
Posted on: 2003/11/8 3:17
From Perth W.A
i'm sure it was just a joke
don't hop on the back foot so soon
Posted on: 2003/11/7 0:00
120y Coupe
From Brisbane
and what be like you...desperate... alone in that dark little corner you got!?
get f*%cked!
Posted on: 2003/11/6 20:24
From Arlington, TX, USA
Razor wrote:
I would prefer manual but gf only drives automatic
Dump her.
Posted on: 2003/11/6 0:46
1973 Datsun B110 Coupe (A15/5spd)
1977 Datsun 280Zed (5.0L/5spd)
From Millgrove Vic OZ
Its easy to put a plate on the firewall drill some mounting holes and fit a stanza clutch pedal and master cylinder.
Posted on: 2003/11/5 6:24
Cheers Feral
(1) 2 3 »
