Re: i need some help 1400 turbo project
Quite a regular
From Finland
I was in dyno two weeks ago and I had in my car 162hp and 241Nm from rear wheels - I was using 1 Bar boost.
I have this twin dellorto blow through system + IC (490x190+70), standard cam, A14, Intakevalves 37 exhaustvalves 33, turbo garret to3.
I
Posted on: 2003/11/22 7:38
A14 Turbo Power
From Pakistan
310 wrote:
...... and two su's on it.
u dont need bigger carbs to successfully turbocharge an NA engine rejettting is unuf for any street engine, as increased air flow also riches A/F ratio. spending money on intercooler is wiser.
Posted on: 2003/11/22 0:37
STRONG IS STRONGEST ALONE. PERIOD
From Brisbane, Australia
EFi not required. I am building a carby suck thru turbo jobby atm. However mine has evolved a little further than most with a custom intake plenum, steam pipe manifold and double dump pipe.
Craig
Posted on: 2003/11/21 9:37
From Melbourne, Australia
what do u need to make it a turbo and do u need efi
Posted on: 2003/11/21 9:02
From adelaide
do it, do it, do it. ull luv the power and kick in the back
Posted on: 2003/11/21 7:09
From newcastle, NSW
Obvoisly you missed out on the heated debate that had been raging for the last couple of days! going on what i've been told it is fullfilling but on the other hand supercharging has it advantages too! all depends on your prefrence and point of veiw!
Posted on: 2003/11/21 5:41
yeah its great i bought the setup off another member, very fullfilling, was suprised at how a stock 1200 performed with 10psi boost
my setup was blow through twin turbo, standard carby, what setup are you thinking of using
Posted on: 2003/11/21 0:30
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Any of you guys turbo charged a dastun engine before, how did it perform was it fullfilling or disapointing, i want to turbo charge my 1400 that has a cam and two su's on it.
Posted on: 2003/11/21 0:01
