Re: Whats Useful?
Not too shy to talk
From Perth, Western Australia
this is totally off topic but i was in a crap mood today and lobster's avatar made me laugh, it's so funny! anyway, thanks lobster.
Posted on: 2003/12/18 4:09
Re: Whats Useful?
From Tas
There's not much point putting an extra leaf in the rear - especially if its in a ute. There is no weight back there, hence no reason to fit another leaf.
Unless you want it to ride like a brick or you carry bricks in the back.
Posted on: 2003/12/18 3:14
Re: Whats Useful?
From Melbourne, Australia
i did it, well i put the extra leaves on instead of 1200 ones, as the main leaf is not interchangable
it stiffened up the rear but also lifted it, caused understeer, so i removed em again
th 120y has one more extra leaf than the 1200 does
Posted on: 2003/12/18 3:09
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Re: Whats Useful?
From Brisbane, Australia
Do 120Y leaves fit a 1200??? If not are they hard to mod to fit??
nup, the main leaf is too long.
Posted on: 2003/12/17 22:31
Re: Whats Useful?
The earlier 120Y used the imported front suspension & disc brakes & these are interchangeable with the 1200. Later 120Y's had Aussie made front end components with Girlock brakes.
These are good brakes, but have a diferent piston dimeter [smaller] & these parts should not be mixed in with the earlier stuff. You would need to rin the whole brake system from the donor vehicle, but running a late 120Y's Borg Warner rear axle is not an appealing proposition as the rear brakes do not fit the Jap axle housing under a 1200 ute.
If you convert to the jap disc brakes, be sure to use the matching rear wheel cylinders, as these too are a diferent bore size & retaining the drum brake cylinders will lead to rear wheel lockup problems, particularly in an empty ute on a wet night.
Posted on: 2003/12/17 10:50
Love your Datsun.
Treat it well.
Re: Whats Useful?
From Warwick, QLD
Cheers
Damo
Posted on: 2003/12/17 8:11
Drive It Like You Stole It
Every Car Has 500hp In The Wet
Team NEW SKOOL
Re: Whats Useful?
all running gear!!!, including brake system, suspension ect ect
Posted on: 2003/12/17 2:50
1200 Coupe Rallycar
Re: Whats Useful?
From Canberra, Australia
gearbox?
diff?
alterrnator
starter motor
Dizzy.
Posted on: 2003/12/15 11:56
1971 Datsun 1200 Coupe
A15 Engine. Holley G180 (32/36 Weber). extractors and 2 inch exhaust.
Standard 1200 4 speed with lightened fly wheel and HD clutch
Stanza front struts and brakes.
15x6 CSA Wheels with 195/50 rubber.
Re: Whats Useful?
From Adelaide, Aust
Most engine parts like the alternator and starter motor might come in handy one day.
Posted on: 2003/12/15 11:10
It's a way of life
Re: Whats Useful?
From Canberra
Does your ute have disc brakes up front? If not they could be usefull (as could the brake booster). Some guys with more knowledge on what fits might be able to confirm what is required to fit them.
Posted on: 2003/12/15 6:52
www.valvebounce.com
motorsport and performance forum
