Re: ca18det troubleshooting
From Sydney, Australia
G,day..Yeah it was probably me.
There used to be a link from Ozdat.net, in the TEchnical Section.
I can upload it to my website tomorrow. I edited the manual to get the order of some of the last diagram pages ok.
Posted on: 2004/1/21 13:22
From brisbane
Bump, one mor try.
cheers mely
Posted on: 2004/1/21 9:56
From brisbane
I can remember a topic that somone sourced the s13 manual and it had a good section on trouble shooting on the ca. Can that be down loaded from the web from somewhere, or is it a nissan manual from a dealer I need?
My engine came out of a 180SX from hong kong. It was the lift back. The plumbing looks different to any s13 ca I have seen at the importers. There is a pressure sensor that is used for the stock computer. It has 3 outlets, 1 T's into the pipe between the compressor and wastegate actuator, one T's into the solid line(vacuum) and the vacuum between the air flow sensor and compressor inlet. But the other I cant seem to track on the imports. It is either just blocked, or runs to nowhere. I have it plumbed into the pressure pipe from the plenum.
cheers crew
mely
Posted on: 2003/12/16 7:51
