Re: A15 Conversion for Dato Ute
From Brisbane Australia
Brother Wollongong, or the Gong to locals is an hour south of Sydney a champion place to visit.
I grew up there but then got packed up and moved to Brissy( I prefer the Gong)
Posted on: 2003/12/25 2:06
1200RC
Sure they made LATE model 1200GX's They were available in 120Y's These are so new that they should be almost out of warranty by now.
These later engines used the square top carbs & there was a 120Y GX coupe running around here for a number of years. If i can unearth the pictures, i will scan them & post one or two.
Posted on: 2003/12/23 11:42
Love your Datsun.
Treat it well.
From Melbourne, Australia
i've never heard of a late model 1200GX motor, did they come in a 120y or sunny or what?
Posted on: 2003/12/23 2:29
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Hi Daz, I have a late model ute xmember for sale in Brissy only problem is that I want to sell it with a late model 1200 GX engine which is complete from w/pump to flywheel
let me know if you are interested
Cheers Ade
Posted on: 2003/12/22 8:55
muke wrote:
dude...where is wollongong...or wahever it is....oops wodonga??
You had better make sure which city you want as there is more than a tankfull of fuel between them.
Posted on: 2003/12/21 11:30
Love your Datsun.
Treat it well.
Quite a regular
Guys,
Thanks for all the info, this is a champion site. Will try to source the later model ute crossmember but this will be difficult to find. May have a look through some of the wreckers in country SA and VIC as they sometimes have more dato ute parts then their city counterparts. Also after a steering box as my current one is looking rather shagged, on the outside at least.
cheers,
Daz
Posted on: 2003/12/21 6:39
From Ballarat, Victoria, Australia
dude...where is wollongong...or wahever it is....oops wodonga...we should meet up....i have a sedan...A15...bored out 2 1600cc....twin 40s...and yes as u said it goes hard as hell....took my first commonwhore (commodore) the other nite...a vr infact....all i need is a new vn radiator....mine is leakin...and with the stocky radiator....it overheats so easily... do u have pics of your sedan??
Posted on: 2003/12/21 3:43
-1200 4 Door Sedan, 2Pac Aruba Blue, Custom White Interior, OBX Racing Seats, SONY Head Unit, FUSION Speakers, 14" Bathurst Globes, Lowered, Powered By: A15 with Twin 40s,
The crossmember & the engine were changed at the same time that the 120Y came out. I think that was in '74. Since you have a REAL 1200 ute, you have two options
1 Secure a crossmember from a '74 or later ute & it will bolt right in, or
2. Modify the right side mounting "tower" to accomidate the slightly repositioned mounting on the block.
You will need to do some wiring alterations to accomodate the altenator which is positioned high on the right instead of low on the left as it now is in your car.
If you are going to pull the cam from the A15, then get yourself a new or reground replacement & do it right. The cam from your old A12 will not work as the A15 has the distributor further back than the early A12 & it requires another drive gear on the cam that the early one does not have.
With the A15, you may well benefit from the removal of the 4.11 to 1 diff ratio & the fitting of a 3.9 to 1 diff from a 910 Bluebird.
I kind of like the GX intake setup for a mild sports road engine. They may not be as impressive as some, but they work well.
Chris
Posted on: 2003/12/20 9:25
Love your Datsun.
Treat it well.
From wodonga, victoria
i run a modified a15 in a sedan and ther were not many dramas in getting it in you may just need to modify the engine mounts by adding a plate to slide the engine back or forward i cant remember which way.
if you want to get any serious power run a set of twin 45's or 40's webers, they go really well with this done to them. try to get your hands on webers and not dellortos, dellortos are to hard to find some one to tune them, there is a place in melbourne that will do it though
Posted on: 2003/12/20 6:18
Not too shy to talk
From perth wa
I've swapped my a12 for an a14 in a 78 ute. It went in with no mods.
Posted on: 2003/12/20 5:31
