Re: CAms, Cams, Cams...
From Auckland N.Z
I took my cam that my mate had lying in his garrage to Tony Marsh and he said it is a "Z" cam and is good for 9500rpm but he also pointed out a tooth on the dizzy drive has been broken and replaced. Not so sure I want to use it now.
I rang Kelford Cams and for $220 theyll grind my cam and match the followers and it will be good for 4000-8500rpm. I wont race on the 25th but it will be worth the wait. I described my motor and head and read out my dyno chart and he recons I could easily get 15-20BHP (at the rear wheels)!! YAY.
I just refited new Bilstiens on the front but its to late and wet to take it for a spin.
OHHHHH its going to be good!!
Posted on: 2004/1/15 11:01
From Brisbane, Australia
pretty much - takes all of 20 minutes to break-in a cam. You can probably squeeze that into your week and a half timeframe!
don't forget to take your cam followers in when getting the cam ground - they need to be surfaced. Any reputable grinder will ask for them anyway.
doesn't matter what cam you start with if you are getting it reground, but watch out for the different locations of the accessory drives (distributor & fuel pump) on early A12 blocks compared to later A series motors.
Posted on: 2004/1/15 8:15
The cam manufacturer will provide the break-in instructions.
They used to be something like: use this special cam lube, and when you start the engine first time, run it at 2000rpm for 30 minutes -- do not let it idle.
Is this still the usual method?
Posted on: 2004/1/15 7:25
Quite a regular
From Perth
shoom,
Try Ranch Automotive in osborne park.
My mates old man works there and they rebuilt, balanced and machined alot of stuff for me when i was building up my old escort.
They have a cam regrind department too.!
Posted on: 2004/1/15 6:20
1980 sunny std dreaming of ca18det
2000 CBR600F4
From Auckland N.Z
Dodgeman I was not aware that one must run a cam in! I guess it makes sence. Oh well another race in a underpowered car. But it should be ok because Ive just installed Bilstiens and saughted out the rear springs (were to soft and low and kept bottoming out).
Posted on: 2004/1/15 6:07
From Perth, West Aussie
speaking of cam grinds... does anyone know what a good cam for my A15 would be? I got extractors with 2inch system and dgv weber.. Its in my 1000 wagon which will be used for towing my catamaran and running stuff around so I need a 'torquer' profile.. nothing lumpy , just enough to bring the afforementioned mods to life :) is there anybody in Perth that could do this also?
Posted on: 2004/1/14 14:08
Quinn
Even if you got it on friday, would you have enough time to rebuild the engine as well as RUN THE CAM IN.
I think the cam manufacturer / regrinder would tell you how long to run it at restricted RPM before you give it a flogging, but this may prove to be a limiting factor.
Chris
Posted on: 2004/1/14 12:55
Love your Datsun.
Treat it well.
From Auckland N.Z
how long do you reckon it would it take? Ive got a race it a week and a half.
to soon?
Posted on: 2004/1/14 12:24
From Invercargill, New Zealand
Around $120 rings a bell.
Posted on: 2004/1/14 12:16
From Auckland N.Z
cheers teretonga
Im going to see Tony Marsh tomorrow and ask him. how much is it for a regrind at Kelford Cams?
Posted on: 2004/1/14 12:14
