Re: turbo sizing?
From Kingsley, Perth, WA
The turbo is on a 2 litre 16valve DOHC FE3 mazda motor in a 1200 ute. Boost threshold is a tad under 4000rpm which pulls until about 7900 odd rpm (where my limiter is at). I need to identify the compressor housing size, upgrade is in the pipeline! I'll post some pics in the photo area, if anyone recognises the size please drop me a line
Posted on: 2004/3/21 16:46
Re: turbo sizing?
From sutho shire
can only with dattodude, as when i was purchasing my TD06 i wasnt 2 sure if it would perform on my ca18det so i checked it out with a few workshops before buying and all gave thumbs up and said best way 2 go! and explained what i needed 2 get the power outer this turbo external gate custom manifold injector ect,
i just cant wait till i its fitted, tuned and dynoed.
Posted on: 2004/3/15 2:17
*1200 ute ca18det (CYA-18T)
256 rwhp at 14psi wanting more power
Team New skool
Re: turbo sizing?
From Sydney, Australia
This is a really big problem with second hand turbos. unless you know where they come from, getting parts, or application information will be quite difficult.
0.5x is quite small for a T04 compressor housing. Normally they are 0.64 0.86 ..
Take a photo of the front (aluminium housing) and the rear exhaust housing. Try and get a clear photo of the detail on A/R.
Guys, please remember that the HP rating on the turbo is just that..an operating power rating. It won't give your engine that amount of HP.
You'd need to run an A12 at 16,000 RPM with tricky fuel to utilise a turbo of that size.
The 0.5 A/R is a ratio thing, so a T04 with A/R 0.54 is much bigger that a T25 with a A/R 0.70. Also remember that there's compressor (intake) A/R and Turbine (exhaust) A/R.
I've heard that intake and exhaust A/Rs should be similar.
Chris.
Posted on: 2004/3/15 1:51
Re: turbo sizing?
From sutho shire
it would prolly be best if u emailed this guy rayhall@turbofast.com.au
he is top notch with turbo's at least u will get the correct spec on this turbo
and he would help u with anything else..
Posted on: 2004/3/15 0:10
Team New skool
Re: turbo sizing?
Quite a regular
From Sydney, NSW
So wot sort of ute do u have? Is it a 1200? Cos f@#k if u got a T04 in a lil 1200 it would blow the engine its way to much power for it. Cos at the moment ive got a T04 in a VL Calais and its got 600hp. But yes neways cant help wiv the size but my dad is a turbo mechanic and he works for Garrett here in Sydney so i can find out.
Posted on: 2004/3/14 23:33
"You can't beat what you can't catch!"
turbo sizing?
Can any of you tell me what size my turbo is that I bought my ute with. Turbine is a Garret T4; BUT the compressor has the following stamped on it: a/r.50 m-12 L
I was told its a TO4E compressor housing, it also has a built in polished inlet plenum, which sticks out about 40mm for the airfilter boot (100mm id) to fit over. Can someone shed light on this??
Posted on: 2004/3/14 17:21
