Re: biggest legal engine for 1200coupe
From Arlington, TX, USA
dat180 wrote:
NZ good like that to, But regardless of what you upgrade to it will cost over $500 for the cert.
That's cool. Didn't know you could do that in NZ...
And I thought our yearly "cert" was too much at $75.
Posted on: 2004/5/22 0:49
1973 Datsun B110 Coupe (A15/5spd)
1977 Datsun 280Zed (5.0L/5spd)
From Rotorua
NZ good like that to, But regardless of what you upgrade to it will cost over $500 for the cert. Money better spent that getting a car that you'll be paying off for the next 3 years!, and everbodies got a WRX!!
Posted on: 2004/5/21 6:13
I know it's slightly off-topic, but I love America.
Nobody cares what size engine we stuff in there as long as the brakes work and the lights work.
Posted on: 2004/5/19 23:02
From Warwick, QLD
In queensland, if you stick within the RTA's ruling, that being 1820cc Turbo engine limit (as the CA18 is 1809cc) Mod plates are only required, which basicaally they just look at you install and say yep thats safe, the brakes are good, then they charge you something like $25 a mod to check out (a mod being, different gearbox, different engine, different mounts, etc......)
But if you wish to go outside the RTA's ruling, like whacking an SR20DET into a 1200, then a full Engineers certificate is needed which cost bout $700.
So if you have the money then you could go an SR20
Cheers
Damo
Posted on: 2004/5/19 22:48
Drive It Like You Stole It
Every Car Has 500hp In The Wet
Team NEW SKOOL
From Rotorua
old_school wrote:
Having said that a few years ago I saw a NZ 1200 in a magazine with a SR20DET.
This wouldnt happen to be a white 1200 coupe? with no. pl8 DATTO?
Saw this car at meremere a few months ago and this car broke into the 10 second club!!
Posted on: 2004/5/19 22:25
From Sydney
are you sure about the 2.3L na? because i have a RTA guidelines for light vehicle modifications thing infront of me and it says for an aspo the rule is
original weight (kg) x 3.0 (this being roughly 720kg x 3 = 2160cc) this stating the original capacity allowed in an engine meaning you can put an L20 in and stroke it to 2.4L but it still counts as 2.0L. the way i see it is you are only aloow a standard capacity engine of 2.1 because i dont think there are any engine above 2150 but below 2160 to be classified as a 2.2L engine and im not aware of any 2.1L engines you may want. not trying to be rude but thats the way i thought it was??? correct me if im wrong?
Posted on: 2004/5/19 14:22
Street Tail Dancers
1200 coupe - A14
From Mandurah, Western Australia
When I got my 1200. The plan was engine swap and I looked in to the SR20. I went to a input wreckers and got the tape out and measured everything up. I came to the conclusion it would be a difficult fit.
The CA18 was considerably cheaper and overall a more logical choice.
Having said that a few years ago I saw a NZ 1200 in a magazine with a SR20DET. It was registered however the vechicle had had considerable firewall and transmission tunnel modifications.
If you want a SR20 and can get the required approval from the RTA. Go for it.
In WA you can get pre approval and guidance when going outside their guidelines. However a engineer needs to become involved. Is this the same in other states?
Jarrad
Posted on: 2004/5/19 13:20
From Sydney, Australia
If the rules are the same as in NSW...yes, you would become bubba's shower buddy after an accident.
The SR20s size also makes it harder to work on. The Gearbox diameter is a squeeze, even in a Auto Tunnel.
I think you'd find a 2.3NA SR20DE would give you enough power, you'd never need to put a turbo on. Mate, with more than 150kW (200HP) at the wheels...You would struggle to keep the car on the road. The torque would make it a monster!
And you wouldn't be hassled half as bad for insurance.
So, it's worth thinking about. But I still think the CA18DET is the go.
Chris
Posted on: 2004/5/19 12:22
Quite a regular
From Brissie
so if the rules are the same i wont be legally able to get a sr20det cause it is over 1.8 turboed.....
what if i get a sr20de and bore it to like 2.3 regester it then get a turbo??? would it work being the only thing would be i get in #### if i have an accident or cops
Posted on: 2004/5/19 11:43
Datsun 120Y 4Dr '76
Datsun 120Y Coupe '74
120Y POWAA
in NSW it's 2.3L NA (not 2.0L)
Mmmmm stroked L series...nice.
Chris
Posted on: 2004/5/19 8:24
