Re: wanted 2" lowered springs for stanza strut ( gemini ?)
From Sydney.au
ive since bought lowered stanza king springs and have cleaned up the strut/caliper. looks good soon to be inserted. 120Y castor rods needed some grinding to fit a bolt next to where it sits on the stanza lower control arm.
Posted on: 2005/3/28 15:25
From Perth W.A
king springs are only about $110 for a pair and are great so not too expensive.
Posted on: 2004/8/9 3:10
120y Coupe
120Y coupe Race car (SOON)
120Y Sedan for the Lady
From Sydney , NSW
evilsim,
to my knowledge all gemini springs are the same (both early and late model). However, did the earlier post say to use a standard rate shortened spring ? Aftermarket lowered may be a little stiffer and hence too stiff for a street car - only a thought. I hope my brother still has a supply of stock springs so I can try it out for myself I suppose it is just a matter of matching the free lengths and working from that point back to the ride height you want.
Cheers
Posted on: 2004/8/8 22:28
From Sydney.au
havnt tried king springs although im sure theyre good but their price would be king size too. if i can pickup 2nd hand ones ill do it.
i can get 1" lowered gemi springs from repco for around $90 which is with discount. but then i'd need to get them compressed and more $$
not sure of which series of gemini springs.. im blindly assuming any gemini spring.
Posted on: 2004/8/8 12:46
From Warwick, QLD
Have you tried King Springs??? They do a low and a super low series. Does any model gemini springs fit??? They have a better damper rate isn't it????
Damo
Posted on: 2004/8/8 11:45
Drive It Like You Stole It
Every Car Has 500hp In The Wet
Team NEW SKOOL
From Sydney.au
i will be using them on stanza struts, without any length mods on the struts. have been told 2" lowered gemmi ones will do. any info appreciated. i can only find new 1" lowered springs thru Repco. havnt had time to go wrecker searching :(
Posted on: 2004/8/8 8:35
