Re: What is it???
Not too shy to talk
From townsville
check the cable from neg to the earth on the chassis and the earth lead on the block. put multimeter on neg terminal and check resistance between it and the block(try a few places so its a consistant reading)should be nearly no resistance or none.
Posted on: 2004/9/16 22:43
Re: What is it???
From South Africa
These Ignition barrels are not so expensive brand new.
Dont bother buying it 2nd hand.
Otherwise do as I've down.
Keep the original barrel in, use a starter switch button.
So, once the key is on the ON position, just use the button to crank up.
I placed the button switch in the place of the cigarette lighter hole,
Walllah, almost keyless ignition
Posted on: 2004/9/16 10:49
Life's a bitch, so f...k it.
Re: What is it???
From sydney
thanx mate just wondering if anyone has a ignition barrel desparetly wanted
Posted on: 2004/9/16 9:52
Re: What is it???
From South Africa
Yeh, do as ang94541 said,
However if its not that, I'sd suggest checking the lug behind the ignition switch.
Posted on: 2004/9/16 9:08
Re: What is it???
From Castro Valley,CA USA
If you short the hot terminal and the start terminal directly on the starter, does it start then? This should help narrow it down a little to the starter or something before the starter.
Posted on: 2004/9/16 8:24
Re: What is it???
From sydney
it wasent that
thanx anyway
Posted on: 2004/9/16 8:13
Re: What is it???
From sydney
ok i will give it a go now
Posted on: 2004/9/16 8:01
Re: What is it???
Hard to say what's wrong with your car ...
But, one of the most common car problems (for old or new cars) is when the battery cables get corroded. The dash lights may come on, but when you try to start it, nothing. This is fixed by removing the cables and cleaning the cable ends and posts.
Posted on: 2004/9/16 7:49
What is it???
From sydney
wen i came home from supernats. the next morning the car wouldnt start as the battery is fully charged and i checked the alternator and theres nothing wrong wif it wen i turn the key nothing at all happens maybe loose wiring??? can anyone help or ever had this problem could tell me what it might be Cheers Rick
Posted on: 2004/9/16 7:46
