Re: what brake booster is the best fit for a 1200
From T'ville
i aint no teacher or nuffing but but da most basik spellin is just a reflection of your intellect
both is not spelt with an 'a' in it for f^ck sake
Posted on: 2004/9/19 14:28
Not too shy to talk
From townsville
I must apologise, I did not realise that our post's were to be published. I will try better in the future to have correct spelling and gramma.
(did I get all that right?)
Posted on: 2004/9/19 0:38
From Newscastle, Australia
the comma should come after childish by the way.....and where is your question mark?
Posted on: 2004/9/18 23:20
Dont die wondering.....
From T'ville
like b310gx said just use a sunny booster/master cylinder and be happy
and can you guys check your spelling before you post, it looks childish with bad spelling, and gramma .
Posted on: 2004/9/18 14:29
From sydney australia
just get a sunny master cylinder,they're 13/16's & set up for front disc's.or a 260z master cylinder,which is what i have,which is 7/8th's.really,all you need is to go to a competent brake place & tell them what size you want for the master cylinder,they should be able to tell you what to buy.to use the datsun m/c's in a lancer booster,you probably have to do some machining work.the outside diameter of the datsun part is slightly too big for the front of the mitsubishi part.a friend of mine machined down the m/c,but now id get the mitsubishi bit made to suit the m/c.the part i'm referring to is the alloy casting which bolts to the front of the booster,& that the m/c bolts onto.
Posted on: 2004/9/18 13:26
From Mackay
can you bolt the 1200 M/C onto the lancer booster?
Posted on: 2004/9/17 12:21
From sydney
ive got a brand new 120y dual system M/C and a 180B booster in my car
Posted on: 2004/9/17 7:02
Not too shy to talk
From townsville
i source a lancer booster yesterday but im confused on what mc to use. lancer one is apparently to small. brake bloke said i need at least a 7/8 bore mc. what size bore on the 120y mc?
Posted on: 2004/9/16 22:57
YepI have a Lancer booster and a 120Y dual system M/C in mine
Posted on: 2004/9/16 12:54
From campbelltown (sydney) australia
the la-lb lancer brake booster bolts straight up to the firewall, and the brake pedal, all u need is to get some brake lines made up, im in the rpocess of fitting the same to my 1200 ute.
Posted on: 2004/9/16 12:41
