Re: Single SU?
I know this topic is a bit old, But I've been doing some research latley for my MGB and came across this post and thought I might share some Ideas. I have a later model 'B' with the Water choked Zenith Stromberg 175 carb. Earlier versions of this car had dual SU HF4's or HIF4's. For those not familiar with the ZS, it was switched for the SU to comply with strickter emmisions regulations around 1975. This led to a decrease in BHP and adjustability over the SU HS/HIF4's. So, I got a set of HS4's and a manifold and starting reaserching tuning of the dual SU's and now I'm here writing this.... so anyway... A little about the SU's (and what I've gathered about the Hitachi equiv.). The letter designations in all of these carbs basicly tell you the size of the carb. IE Hitachi HJG46W is the basic equiv. of the SU HS6 or the ZS 175 or a 1.75" carb. The Hitachi xxx38x (sorry didn't write down the exact model of this carb) = SU HS4 = ZS 150 = 1.5" Carb. and then the SU HS2 = 1.25" carb. The Z cars used the equiv of the SU HS6's in two styles. The round top (a copy of the HS6 as far as I can tell) and the Flat top (Different from the round top and suposedly less reliable, and tune differently than the SUs).
Now, I'll admit that I'm not that familiar Datsun/Nisson engines, but, I think that info on British engines will translate well. A specific size engine will have an optimul (or close to it ) carb selected for THAT size engine. Modifications to the engine will require rethinking the carb choice, but I will touch on that in a bit. So, Given these 3 carb sizes (there are more) what are the given set ups for engine sizes?
Duals first as these have a bit more WOW factor:
997cc to about 1300cc (Minis and Spitfires) use dual HS2's (1.25")
From about 1300 - 1800cc (MGB, Austin 1800) use dual HS4's (1.50")
~2.0 and up use Dual HS6's (triple HS4 or HS6's for some 6 cylanders) Z cars, some Volvos, GT6's, etc.
As for single carbs you basicly see a 1 size higher carb.:
997-1300 - HS4 (ZS 150)
1300-1800 - HS6 (ZS 175)
> 1800, I'm not really sure HS8's perhaps?
I think that it might have been said here already, but using too much carb will just bog down your engine, especially in the case of dual carbs. That is of course unless you have modified your engine. Modifications would include but are not limited to: P&P head, Headers, Hot cam, Over bored pistons, etc. Basically without modifications the engine will not have enough vacuum to properly operate the carbs. It might run, but it will be very difficult to tune it properly. Now for a single carb, you could possibly go to a higer than starndard carb and be able to tune more easily, But I don't see the point if the engine doesn't have the Mods to really benifit from it.
As an ending note, the SU carbs are highly tunable. there are some 300 odd needles to choose from, different springs, as well as other tricks. SU's abound, just check the e-bay listings for the MGB in particular.
As for the original Post, a Single Z carb could work on a 1.4L. A single SU HS4 or HIF4 would probably also work well as well as a ZS 150 or 175. If the engine was stock, I would probably start off with a 1.5" inch carb. Headers and a little head work could see the benifit of a 1.75" carb. As for duals I'd look into fitting a dual HS2 setup from a spitfire , or a mini.
You're on your own as for manifolds. Check Lynx, Cannon, etc. for aftermaket conversion manifolds, who know's you could get luckey.
Hope this is usefull to someone =)
-D.
Posted on: 2005/8/8 5:02
Re: Single SU?
Yes, I'm interested. I'll have to update the carb article since you've pointed out something is not quite correct with the article.
Posted on: 2004/11/18 5:56
Re: Single SU?
From Dallas TX
Right L18_B110. I've been doing some searching and I've found just that.
The early Roadsters (1.6L and smaller), the GX Hitachi's carbs and at least some of the 510 carbs were 38mm (1.5"). The Z's and 2.0L Roadsters are 46mm (1.75"). That number comes straight out of the part number: The Z's are HJG46W (46mm) and the early Roadsters are HJB38W (38mm). Still trying to figure out what the "B" and "G" mean - there is also an HJL which is a 510 "flat-top" Hitachi.
So in short, my 240Z carbs will not fit on a GX manifold unless I bore the manifold. I've also found an article arguing against putting the larger bore carbs on an engine smaller than 2.0L (http://www.jetlink.net/~okayfine/su/zsus.html).
Well, for now I'm looking for some more details on which 510s' used which carbs to widen the number of interchangable parts. But in any case, I still dont' have a GX manifold anyway... still looking for one. BUt when I finish my "research" I'll post a more comprehensive report here, if anyone is interested anyway.
Michael
Posted on: 2004/11/18 4:01
Re: Single SU?
From Brisbane, Australia
A series Hitachi "SUs" are 1.5"
Z car Hitachi "SUs" are 1.75"
Posted on: 2004/11/17 4:47
Re: Single SU?
From Dallas TX
I think the reason the Z guys call the carbs SU's is because that's the best way to differentiate them from the flat top Hitachi's. Most Z owners wouldn't be caught dead with a set of flat tops - they generally refer to them as "boat anchors" so to avoid any confusion if they're talking about Hitachi's they shorten "SU style Hitachis" to "SU's". The one's who know their stuff know they're not really SU's. LOL Anyway, I'm getting off topic here. I'll post what I find out about the carbs.
Michael
Posted on: 2004/11/16 13:56
Re: Single SU?
Excellent, do the research then share your findings with us. The article shows which ones the A12GX engine uses. Keep in mind that Part Numbers will be different -- just as they are different between California and non-California cars and between years. Instead, focus on the carburetor type (HJE38W). As the article states, these were used on the GX engine and on the 240Z.
Real car guys know exact engine numbers and carburetor types. Maybe some of those Z-guys are just posers Not saying they aren't nice guys.
Posted on: 2004/11/16 6:58
Re: Single SU?
From Dallas TX
Sorry dd - bad habit from hanging with Z folks. They all call the round-tops SU's.
I've looked at the carb link but still didn't find a solid answer about whether the carbs are the same or not. The P/N given doesn't lead to any Z car hits on google so they're probably different. I'll do some research. Thanks
Michael
Posted on: 2004/11/16 5:34
Re: Single SU?
> I'm wondering if the size is different between the US Z model and the GX model
The answer is in the Which Carburetor article.
Two carbs don't have much more airflow than one due to the design of the intake manifold, so it doesn't matter much whether you use one or two. Just use whatever the manifold is designed for.
And no Datsuns came with SU carburetors. They are Hitachis.
Posted on: 2004/11/16 4:35
Re: Single SU?
From Dallas TX
Yeah I've been looking for the GX setup but they're hard to find in the US (and hard to find someone to ship it to the US from Oz). That's why I'm wondering if the size is different between the US Z model and the GX model. Maybe you only need one if it's a higher flow carb. ANyone got a spec sheet on the GX carbs? That could answer my question. I'll go look through the Tech articles to see what I can find there.
Oh yeah, and the reason I'm considering the US carbs is because I have a really nice set ready to use. Just don't have a manifold or know whether I need them both or not.
Michael
Posted on: 2004/11/15 19:07
Re: Single SU?
In this case, the GX model refered to is the twin carb Japan Domestic Model, [JDM] & not the US single carb model.
These are just the ticket.
Posted on: 2004/11/15 18:55
Love your Datsun.
Treat it well.
