Re: throttle position sensor? (t.p.s)
From durban, south africa
how does one test the tps? cause the car is not going right, flat spot between 4500 and 5500+- it doesn't feel like it is running and the ecu says it is malfunctioning.
Posted on: 2005/2/21 6:59
VW chassis
fibreglass body
A-14
280 cam
ported head shaved 1.5mm
extractors with 2inch s/s pipe
webber 38 dgas.
to come........
Dellorto 36 drla
turbo
and then maybe some gas
From Melbourne Vic
the Throttle postition sensor is a sensor that senses the throttle position... and its one of the main diagnostic sensors that gives the ecu information. i would have thought if it was stuffed it would go into "limp home mode" which generally sees a very rich mixture, rather than a lean inducing pinging. is it plugged in correctly?
Posted on: 2005/2/20 22:52
CA18DET 1200 lagwagon retired
LAG510 - SR20DET 1600 sedan
1000 wagon daily - A series magic
hey guys what does this do? does it control timing and fuel amounts? i ran the fault finding setup on my e15 ecu and said the the tps was faulty, now as you have heard i also have a pinging problem could these two be linked?
many thanks
nicholas
Posted on: 2005/2/20 16:38
VW chassis
fibreglass body
A-14
280 cam
webber 38 dgas.
to come........
Dellorto 36 drla
turbo
